SOURCE: cant save to pdf in printmaster gold 17
found the fix for printmaster 18 broderbund pdf saving problems...
1-close all open programs and return to desktop.
2-click START and choose CONTROL PANEL
3-click PRINTER
4-right click on BRODERBUND PDF CREATER, then select PROPERTIES (the broderbund PDF creater properties window will open)
5-click the PORTS tab, then select ADD PORT button. (the printer ports window will open)
6-click NEW PORT, then enter PMPDF in the ENTER A PORT NAME window, then click OK
7-click CLOSE at the PRINTER PORTS window. you will now be looking at the broderbund PDF creater properties window
8-a check mark will be located next to the new PMPDF printer port. click APPLY. the broderbund pdf creator will now be located next to the new port. click OK.
9-exit all windows and restart the computer. once the computer restarts, you can save your project as a pdf file.
SOURCE: I WOULD LIKE TO CONVERT
If I was in your place I would use a direct connection if both computer's are connected to the internet ...and in the same default gateway ..its easy ..cause you can find the other computer into my network places folder..after you select the view workgroup computers task ...You will have to disable the firewall in both machines and after that you will have access on the other computer just like in my computer folder..and copy files...
If they are not on the same workgroup...than you can use a remote control program to transfer the files directly ..THis one will do the job ..,all you have to do is to install it on both machines ..open in the remote one ..and in yours..and get the ed and password offered by the program and connect to it ..after that you basically have ful access to it ..even tranfer files..
here is the program :http://www.teamviewer.com/index.aspx
If the machines are not connected to the internet than the only way is to use a large memory stick or an external hard drive ...or just get the hard drive from the one you need the files and connect it temporary to the other one ..and you will find its partition in My computer ..after that just copy paste the files in the other partition from the computer you intend to use..
SOURCE: I can't convert printmaster files
Here is
a step-by-step description of how to use the Professional Printing
option to convert PrintMaster files to PDF:
1.
In
Tools/Options/General Options, check the box beside "Optimal Printing
Resolution". 2.
Go to
File/Printer Setup/Printer Setup. 3.
Under
"Name" select Broderbund PDF Converter v2.10d 4.
Next, go
to File/Professional Printing. 5.
Select
"Save As PDF". 6.
At the
next screen, type the name of the PDF file you want to save in "Project
Name". 7.
Under
"PDF Resolution", select 600 dpi. 8.
Click on
"Save As". In the next window, browse to the folder in which you want to
save the file (for example: My Documents). 9.
Click on
the "Save" button. 10.
PrintMaster
will save the PDF file to the folder you selected. 11.
Open the
file in Adobe Acrobat to make sure all the elements and pages are there
and that it looks as expected. 12.
Once you
are satisfied, upload this file to Print Pelican. There
are two caveats: 1. Because it is made to print cards and calendars to
your laser or ink-jet printer, PrintMaster expects page sizes to be
standard ones such as 11" x 17" or 8.5" x 11". Custom page sizes (such
as 7" x 10") may not work properly. 2. Do not use backgrounds or
elements that print to the edge of the page. This is a feature that will
not print properly from PrintMaster. Make sure your pages have white
margins with nothing printing on them.
SOURCE: I have been using my
Hi conniejm04
Yes , that's the reason why :
Here is the fix : http://forums.encoreusa.com/tm.asp?m=37889
Best regards ,
fanaudi .
