Hi
I have a Bellini microwave 30lts BTMW30
it wont stop beeping and the clock will not set and when I turn it off and on the clock/timer/cooking time shows 33:33 all time
Did you find out what caused this or how to fix it? Mine is doing the exact same thing and I don't know if I need to get a new one.Did you find out what caused this or how to fix it? Mine is doing the exact same thing and I don't know if I need to get a new one.
Hi Kate, Did you manage to fix this. We have the same problem with our microwave. Appreciate any useful inputsHi Kate, Did you manage to fix this. We have the same problem with our microwave. Appreciate any useful inputs
You can't post conmments that contain an email address.
My suggestion is to test that the door switches are working properly. If the board can't see that the door is closed it will not allow the unit to start cooking for safety reasons. This is easily seen when you open the door of an operating microwave and it stops. This is a fairly common problem. I hope this helps. Good luck.
Operating functions:
To set the clock, press and hold the clock/timer button for three
seconds. A clock icon will appear on the left side of the screen. Input
the time using the numerical buttons and then click the clock/timer
button to save the time.
To set the timer, press and release the clock/timer button so that the
display shows all zeroes. Enter the desired time using the keypad. Press
start/stop to start the countdown. The countdown may be paused by
pressing the stop/start button and resumed by pressing the same button
again.
When countdown is complete, timer will beep continuously for thirty
seconds and display will flash. Timer will then beep every ten seconds
for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up,
press clear/memory so timer reads all zeroes. Press stop/start and a
plus sign will appear on the right side of the screen as the timer
begins counting up.
hi,
The F2 code is a keyboard failure. Since it's intermittent I would check for a loose wire/connection. open the control panel and reset the ribbon cable on the circuit board....
IF IT TURNS ON AND SOUNDS LIKE ITS COOKING IT IS PROBABLY THE HEART OF THE MICROWAVE THE RADIATION PART WENT OUT IT IS MORE RECOMENDABLE TO REPLACE THE WHOLE MOCROWAVE
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
