Hi all, got a Artisan 5KPES100 and I'm not getting any water thru' the espresso boiler. Machine is making an occasional noise & sometimes just releasing a bit of steam thru' the espresso boiler, but no water. Have replaced the water pump, but still no water being drawn from the water tank. Hose is NOT kinked & there IS sufficient water in tank. Could it be the solenoid? Can I swap over the solenoids(coils) to check as frothing boiler is still producing water & steam? Any ideas would be magic.
Thanks Piers for the service manual! I was looking for that.I just had the same problem with my machine and I found out that the holes in the brew head assy (the plate that holds the shower screen) were clogged with coffee. I took it off, pressed a pin through the 5 holes and my machine is working again. Good luck!
Hi Not exactly a solution but I have uploaded a service manual I had on to megashare http://d01.megashares.com/dl/bf4e300/kitenaid service manual 5KES100.pdf
it may help you find the problem.
