The model number is CER3725AA but you left out one letter at the end.there's a computer board in this also the clock assy. everything runs through this,it sounds like the clock assy.is bad or you can check the sensor first but it sounds like the clock.on older machines this would be a runaway thermostat but the computer does this now.first you can try shutting the power off to the machine for 5 minutes to see if it clears the computer,sometimes they have to be restatrted just like your house computer,if that doesn't help you can try changing out the sensor,this tells it how hot it is in the oven,there should be a tech sheet on the back of the top console or down near the draw,it will tell you how to read out the sensor with a meter,i think it's 1080 ohms but the sheet will tell you,if the sensor is good it's gonna be the clock assy.the part numer is 5701M829-60 and it's 180 dollars.the sensor part number is 12001656 and it's around 45 dollars.good luck.
