Go into ur tv menu again,go to sound option again check what on the writing highlight on the tv SOUND SETTING now is it said VARIABLE SETTING.Than it is the sound setting problems,go into that highlight word VARIABLE SETTING just press the enter button on the remote to change it back to FIX SETTING.This should and will solved ur tv sound setting problems.If the sound setting already highlight word is said FIX SETTING.Than the tv have bad incomming broadcasting input signal cable or ur tv have bad or dead speakers problems to the tv itself.Not Sound Setting problems.
HERE'S THE ANSWER TO YOUR PROBLEM:
There are times that TV sound problems does not require you to call for a technician. Some TV sound problems are just easy to repair, and you can just do it yourself. Try to do this one:
1. Press the "Mute" button on the
remote control or press the "Volume Up" button. The most common cause of
no sound is accidental use of the television's "Mute" function.
2. Make sure the speaker source
switch on the back of the television is switched to "Int" if you are
using the television's speakers and "Ext" if using surround sound. If
not set properly, you will not hear the television sound.
3. Access the television's equalizer by pressing the "Menu" button,
selecting "Sound" and then "Equalizer." A list of sound options will
appear on the screen. Use the up and down arrow buttons to select the
option you want to adjust, and the right and left arrow buttons to make
adjustments to the option. You should use this method of adjusting the
sound settings if the audio output is in some way unusual.
4. Check the surround sound speaker wires and make sure they are secured to
the audio jacks on the back of the television. In addition, ensure that
the surround sound speakers are powered on.
If it does not work still. Contact your service provider. Thanks...
