Zanussi TC7114W Electric Dryer Logo
Posted on Aug 07, 2008
Zanussi tc7103w power light on nothing working if i hold in the start button i can hear the timer going on but nothing else
rdial54
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Sep 03, 2008
rdial54
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
Helped
40689
Points
22
Check the relay switch.
I have a Zanussi Electrolux TC7103W condenser drier and for some reason the empty water light keeps coming on even though the reservoir is usually only half full. I have tried emptying it and tried un
Make sure lint build up is clear behind condenser
Sep 29, 2012 • Dryers
Where does the tension spring go on a zanussi tc7103w?
Needs to be hooked on to motor so there is lots of tension pulling on the motor.if i remember correctly there is a long thin bolt holding the motor together and this is the place to attach spring. Hope this helped Tim
When you turn on the drier it trips the electricty. there is power in to the power switch but when you turn the dial it trips the fuse box. the model is TC7103W
an electrical earth leakage will cause the trip. possibly the the heating element. but the motor or wiring fault can do it. you could try disconnecting the heater if the electric stays on. then change the element.
Zanussi tumbledrier TC7103W not heating
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Zanussi condenser drier: tank full light on even though empty
its either going to be fluff in the float which you can get at by taken the side panel off .or its fluff in the valve behind the water tank
1helpful
Zanussi Tumble Dryer Model TC7103W ** Heat
have u changed the thermostats if not change these these r what let the heater element get warm if this then works then the element u changed will more then likely be OK m8
Mar 10, 2008 • Dryers
Zanussi tumble dryer model TC7103W ** heat, machine runns ok, changed compleate heater unit including thermostat.
it could be the timer what sometimes happens is a wire can burn out or have a break in it have had some dryers do this to me and have had to change part of the wiring to fix the customers dryer
TC7103W - electric dryer
there is a lint blockage between the water collection box and the pump
My zannusi dryer is will not dry clothes on hot setting
thermostat in door part no 1258406014 should do the job colin
Top Zanussi Dryers Experts
Bill Eager
john h
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
