SOURCE: Sharp LC-32P70E TV: EPG suddenly not showing
hello, this sounds more like a cable or satelite problem. hame you tried reseting your cable or sat box? usually when you reset the box it will download the guide again...
SOURCE: Everything on the TV works EXCEPT live TV.
Please clarify a few things. Are you using cable TV, satellite TV or a TV antenna? If cable, are you using a set top box (and is it powered on) or does the TV convert the cable info. If satellite, is the set top box powered on? If off the air (antenna TV), can the TV receive the new digital signals and if not, do you have a digital converter box between the antenna and the TV?
SOURCE: I have an external DVD Recorder / Player attached
I have a LG tv set. When i press the tv/av button on the remote my tv shows av1, av2 earlier but now it is showing only av. So i am unable to watch my dvd player. Need help.
SOURCE: Not able to scan for digital OTA channels on a JVC LT-32X667 LCD
Seeing as it does not have a digital tuner in it, I would think this would be the problem, you will have to get a box for it.
SOURCE: My Thomson Top up TV box will not record. I go to
Sounds to me like your hard drive is full. Do you use the topup tv part of the box? If not, deselect all the topup tv channels. This will free up a significant amount of drive. Failing that, you'll have to delete some of your programs, sorry!
To deselect topup tv channels;
Go into the menu option, Customise Top Up TV Anytime, and de-activate all the selected channels
