Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Codefor Appliances
heatman101
SOURCE: Error code PF
THIS is a "Power Failure " Clease the code (press Cancel button) and see if it starts up
SOURCE: PF display on my maytag neptune
it stands for power failure. i would unplug the machine for 5 or 10 minutes and that should reset the micro computer.
Hello & Welcome to FixYa
PF error code means power failure and is displayed when the circuit board also known as the electronic control board goes bad and needs a replacement. Before replacing the control you can also check the thermal fuse which is inside the rear panel on the blower wheel housing and replace if it reads no continuity. Please get back to me if you have any other questions.
Kevin
