Question about Avid Juicy Ultimate Hydraulic Disc Brake , 160mm, Front
Hi there, i have bought a used bike with Avid Juicy ultimate brakes. the back brake was sticking, so I took it completely apart cleaned the pistons, and reassembled with new oil and bled system. the brakes are still sticking, albeit less than before. Also, when I hit a bump, they chatter very loudly...(like the sound of a twig cought in the spokes of a turning wheel, but much faster). Someone told me that first option should be to change the seals in the leaver, and this may address the sticking problem. my question is, do you agree? and will this also fix the chatter issue? you advice is appreciated. Regards, Dan
    Master:
  • 388 Answers
If you already overhauled the caliper, I would overhaul the lever as well. In fact, I usually overhaul the entire system instead of one or the other. As for the chattering sound, it sounds like the rotor is catching the edge of one of the brake pads. Check to see if the pads are retracting fully or see if the pads are loose in the caliper.
Posted on Aug 17, 2017
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: brake adjustment :: too spongy
try these links:
http://forums.mtbr.com/showthread.php?t=464735
http://www.sram.com/en/service/avid/view.php?catID=1&subcatID=1
Posted on Feb 04, 2009
SamThePirate
Christian Samuelsen
  • 81 Answers
SOURCE: Avid juicy ultimate, rear disc brake vibration and noise
It is a lose bolt somewhere, OR somebody has touched your rotor with their hands OR there is oil in the pads.
Check ALL your bolts for correct torque, buy new pads and Rubbing Alcohol and install them AFTER you clean off the rotor and your hands with the Rubbing Alcohol. TRY not to touch the rotor or the pads with your hands.
Posted on Jan 10, 2010
Anonymous
  • 16 Answers
SOURCE: bought a set of avid juicy seven ultimate brakes,i
take the wheel out insert a very large flat bladed screw driver up into where the rotor would sit and lever the pads back in very gently with the screw driver.
if this does not shift them they will need re-built by a Sram bike shop.
Posted on Apr 14, 2010
I bought avid juicy ultimate front and rear brake set no upper clamp to secure brake to handlebar, match maker setup was used. How or where do I find oem clamp?
I am assuming you are looking for the clamp portion of the brake lever.
If you do a google search for the following you can find several options on-line, or go into your local bike shop and have them order for you, they may even have in stock if they do alot of work with Hydraulic brakes.
Search: Avid Juicy Brake Lever Clamp or Avid Hydraulic lever clamp.
Here is a link as an example of a result.
Dec 23, 2010 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Avid Juicy 7 disc brakes:The front wheel was removed and the brake lever squeezed while the wheel was off. The front wheel goes on, but does not spin freely. It turns easily, but not freely like it...
It sounds like you have a piston that is not fully returned and is sticking.
Get a big flat bladed screw driver, take the wheel out and very carefully insert the screw driver into where the disc would sit and use the screw driver to try and push each brake pad back in without damaging your brake pads.
If this works go to a local bike shop and ask them for a avid brake insert for transporting your bike so this does not happen in future! :)
Jan 13, 2010 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Jammed Avid Juicy 5 brake piston
Sounds like you need to strip down the caliper and clean it out im afraid. How about trying a LBS?
(usually its caused by a dry seal and the piston has to be forced out by putting an air line onto the caliper bleed nipple and blasting air into it to force it out - *be careful if trying this!!**)
Jan 07, 2010 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Dec 30, 2009 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Brake pads dont retract
you will need to retract them with a small c clamp, thus slowly pressing the calipers back into cylinder.plz rate-bozcro
Sep 16, 2009 | Avid Juicy 7 Hydraulic Disc Brake 2008...
Brake pads tightening up
use a flat screw driver and push the pads back in on the calliper. Be gentile though.
Jul 30, 2009 | Avid Code Hydraulic Disc Brake
Brake pads are shut fairly tight. Can't get disc
Your brakes adjust automatically (so when the pads wear down your levers don't get looser). What you did was pull the brake lever and it adjusted making the pads shut.
Anyway all you need to do is take a wide flat-head screw driver and wiggle it back and forth between the 2 pads.
Jul 10, 2009 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Bought a set of avid juicy seven ultimate brakes,i squeezed the brake lever and now the pads are shut tight how do i slacken them off again!
Mar 23, 2009 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Avid Juicy Ultimate Hydraulic Disc Brake , 160mm, Front Logo
260 people viewed this question
Top Avid Cycling Experts
Michial Gueffroy
John Egan
John Egan
Lawrence Oravetz
Are you an Avid Cycling Expert? Answer questions, earn points and help others
