New cartridge wouldnt print but sounded like it was printing. You can check ink levels clean or align cartridge by pushing menu then tools. I cleaned contact points w qtip and alcohol. What seemed to work is putting alcohol on cartridge where ink is released and putting back into machine wet did this three times first time little dots of ink then a faint print and now it is printing must have been dried ink further then I could access.
SOURCE: My fax won't print, neither faxes nor copies. The
Though the ink level it said was "6 / 8", when I removed the cartridge to examine it looked bone dry empty to me. I replaced the ink cartridge. It works fine, and reports the ink level as "8 / 8".
SOURCE: Canon JX 210 P Ink Level reset?
its not recommended to refill the cartridges as it causes problems!It recommend getting a geniune cart!
SOURCE: i have lost my manual
You can find instructions here on page 39.
http://static.highspeedbackbone.net/pdf/HP-2140-FAX-Machine-Manual.pdf
Thanks
-Sa_Les_Ski
SOURCE: My 2140 HP Fax will
you might need to update your driver, which you can do at the following site.
http://www.driversquad.com/driver.php?option=o&prodid=172&cust=HP+USB+download_AD_search.swagbucks.com_1&channel=&subid=201_US*DR_o&roia=!iicYvq1BAAKLOkMAAAYOVQAAZT5CAABnCA-A
or if all else fails, re-install your software, which you can also do through HP's website
