HP Compaq nx6310 Notebook Logo
Posted on Aug 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unable to format hard disk.
Unable to delete or format C: hard drive after several attempts.
Tried every available steps on the internet but in vain.
Hard drive corrupted & infected by virus.
  • manojdjoshi Dec 10, 2008
    i have same problem i also use fdisk, partition manager, windows xp format, vista format and low lavel format. i have 2 partition ntfs.
    many time i am format and repartition but all file and partition still have same as after repartition. do not show any error.i thik it infected by mbr or bootsector virus.maybe hdd damage. but how possible all file and partition still fixed after partition.pls any one tell me solution for it.
Iqbal Husain
Level 3:
  • Master 655 Answers
  • Posted on Aug 07, 2008
Iqbal Husain
Master
Level 3:
Answers
655
Questions
Helped
277267
Points
1835
Ady,
You did not mention what steps you have tried. and what the problem occurs when you try to format. It also depends which OS you are using.
There is a solution very easy to use. If you have Win98 or older version then try to boot with command prompt only aund then run FDISK. Using FDISK delete all partition and create new partions, then try to format and install your OS.
For Boot Disk you can surf/download from BootDisk (click here)
If you want detail help, please post your problem in details.
Thanks
Iqbal
WHILE EXPORTING THE TALLY DATA IN EXCEL FORMAT,ERROR OCCURED UNABLE TO SAVE FILE.PLEASE GIVE ME A SOLUTION
You can be getting an error notice when attempting to export Tally data in Excel format for a number of reasons.
You might attempt the following troubleshooting steps:
If you're trying to save the Excel file somewhere, be sure you have the right rights.
You might not have the required permissions to save the file if you are attempting to save it in a restricted place or on a network disk.
Try storing the file somewhere else, such your desktop or another folder.
Make sure you have enough space on your hard drive to save the file.It might not be possible to save the Excel file if your hard drive is full or nearly full.
Try removing unnecessary files or programs to free up some disk space.
Verify the file name and path for any special characters.
While saving the file, issues may occur if the file name or path contains special characters like slashes or colons.
Change the file's name while avoiding special characters.
Check to see if the Excel file is open already.
It might not be possible to save the file if it is open in another program or instance of Excel.
Close any open Excel windows, then try exporting the file once more.
A different format might be tried for the file's export.
Try exporting the file in an other format, such as CSV or PDF, if you are unable to save the file in Excel format.
If none of these fixes the problem, you might need to contact Tally support or your IT department for more help.
3answers
Message on LaCie Hard drive says Hard Drive is full, but I cannot clear
Ensure that your system drive C: is not full, or you get similar troubles. When the external hard drive start giving this kind of troubles usually it is becouse of a bad FAT, the only solution is formatting the hard drive. Store your 15 GB elsewhere and format it.
tip
Creating a bootable flash drive
<p><b>Resolution:</b><br /> <p>The USB Flash Drive must be configured with an active primary MS-DOS partition. It must also contain the boot files. Follow the steps below to create a bootable USB Flash Drive. <br /> <p><b>Requirements:</b><br /> <ul> <li> Motherboard with BIOS that supports USB boot. <li> USB Flash Drive that may be erased. <li> Bootable floppy disk or CD with Fdisk and Format commands. </li></ul> <p><b>Directions:</b><br /> <ol> <li> Plug in the USB Flash Drive. <li> Make the USB drive the only bootable hard drive. <b>Method 1:</b><br />If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. <b> Method 2:</b><br /> Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. <b> Method 3:</b><br /> Unplug all hard drive cables inside the case. If the cables are unplugged the computer cannot detect and boot to the hard drive. <li> Insert the bootable floppy disk or CD into the appropriate drive. <li> Restart the computer to the bootable floppy disk or CD. <li> At the command prompt, type: FDisk. <li> Delete and create a new active primary DOS partition. <li> Use FDisk to delete all partitions from the USB Flash Drive. <ul> <li> In FDisk, press the 3 key to Delete partition or Logical DOS Drive. <li> If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition. <li> After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER. <li> A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER. <li> You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER. <li> The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu. </li></ul> <li> Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2. <ul> <li> In FDisk, press 1 to Create DOS partition or Logical DOS drive. <li> Press 1 to Create a Primary DOS Partition. <li> The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER. <li> The next screen prompts that the computer will now reboot. Press ENTER to continue. </li></ul> <li> Exit FDisk and restart the computer. <li> Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected. <li> At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER. <li> At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER. <li> Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\&gt; command prompt. <li> Change the settings made in step 2 back so that the computer operates normally again. </li></ol>
on Mar 14, 2011 • Computers & Internet
tip
Creating Bootable USB Flash Drive.
Requirements:
  • Motherboard with BIOS that supports USB boot.
  • USB Flash Drive that may be erased.
  • Bootable floppy disk or CD with Fdisk and Format commands.
Directions:
  1. Plug in the USB Flash Drive.
  2. Make the USB drive the only bootable hard drive. Method 1:
    If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. Method 2:
    Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. Method 3:
  3. Insert the bootable floppy disk or CD into the appropriate drive.
  4. Restart the computer to the bootable floppy disk or CD.
  5. At the command prompt, type: FDisk.
  6. Delete and create a new active primary DOS partition.
  7. Use FDisk to delete all partitions from the USB Flash Drive.
    • In FDisk, press the 3 key to Delete partition or Logical DOS Drive.
    • If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition.
    • After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER.
    • A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER.
    • You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER.
    • The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu.
  8. Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2.
    • In FDisk, press 1 to Create DOS partition or Logical DOS drive.
    • Press 1 to Create a Primary DOS Partition.
    • The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER.
    • The next screen prompts that the computer will now reboot. Press ENTER to continue.
  9. Exit FDisk and restart the computer.
  10. Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected.
  11. At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER.
  12. At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER.
  13. Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\> command prompt.
  14. Change the settings made in step 2 back so that the computer operates normally again.
on Mar 31, 2010 • Computers & Internet
I have a WD 3200BEV External Hard Drive, and it won't show up on my computer. I was formatting but had to cancel it then it stopped working! PLease help!
Hello, on Windows 7 I was unable to have the OS assign an existing or new drive letter. I hope you were lucky enough to not lose any critical files (I'm not sure I was :-). But after numerous attempts of trying to recover the disc and even attempting to re-partition on both MAC and PC, I decided to delete the disk and reformat on Windows 7.
After deleting the partitions, I right clicked on the disk and selected "New SImple Volume." Following this wizard got my drive functional again.
Cheers
2answers
Unable to delete data or format or partitioning samsung HDD
Have you tried booting from a Windows XP CD? If you have one available you can boot from it, delete the partition and format it. Works all the time for me.
Kingston 32gb pen drive unable to copy or delete the files writeP
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Unable to Format WesternDigital USB Hard Disk
Are you formatting a new disk or an existing one? Keep in mind that the rest of us do not know all the details that you know unless you tell us & thus it will take much longer to resolve your issue.
You said "after you tried it with XP CD". Dont know what you mean. What program did you use the first time & what steps did you do?
Unable to delete or format C: hard drive even though drive says "HEALTHY"(system)
You can't delete the drive in which you are operating and reformat it. You need to do a system recovery with computer supplied CD or reinstall Windows with WIndows CD.
You know that all will be lost.
Unable to delete or fomat hard drive.
1) You cannot format the OS partition using Windows “Computer Management”
2) If you are trying to format another partition or another Drive in your computer and you can not do that thru “Computer Management”, then you can format your drive using a Windows Cd or any Partition Utility tool. (Using that you also can format your main (OS) partition)
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
