The remote model number for the Quasar VV2008 is VSQS1570 and can be ordered from Panasonic at 1-800-221-7262 or Go to a Family Dollar store and purchase the grey RCA universal remote for $6.00 about 6 inches in length. When you are ready to program it for the Quasar VV2008 push the code search button then the VCR button and enter 0162 then push enter. The red light should go off and the remote should turn the TV/VCR off and on. It worked for me 4/19/2013
SOURCE: set up for cable
You might be able to restore the factory settings by pressing "play" and "FF" simultaneously and hoding them down until the set shuts off (about 5 seconds). Then when you turn it back on it will lead you through the setup routine, which includes auto channel select.
Plan B would be to buy a universal remote.
SOURCE: Quasar model VV2008 tv/vcr
in side the mother board(kit) there should be vertical IC gone. check the vertical section for the IC number and replace it , this will solve ur problem
thanks
SOURCE: I have a Quasar tv/vcr
Sometimes the universal remotes do not compromise fully with certain models especially with combo models.
So you might a different type of universal type to connect with the Quasar codes, but it is ideal if there is the model mentioned in the manual of the remote.
Volume and channel working is what is most important and should be considered good enough.
