Question about Xerox CopyCentre C118 Copier
Error U4-1000 (Xerox CopyCentre C116 copier)
    New Friend:
  • 54 Answers
U4-1000 Indicates Fuser on time failure
Follow these steps:
1. Check for paper on the fuser.
Y remove paper N proceed to step 2
2. Check the installation of the fuser assembly, make sure it is securely installed.
Y reinstall fuser N proceed to step 3
3. Remove the fuser. Check the conductivity of the contact points of the thermostat, are the contact points connected
N replace the fuser
Posted on Apr 15, 2011
6ya staff
SOURCE:
How do I turn off copy-card default on xerox copycenter c123
http://www.support.xerox.com/support/copycentre-c123-c128/support/enus.html
This is how to turn off Auditron but this is the same menu as "foreign interface device" or copy card.
Jan 17, 2014 | Xerox CopyCentre C123 Copier
Xerox Copycentre C20: Copier doesn't scan top 1-3 inches of page. Happens intermittently. When this happens, it moves everything else on page to the top of the copy, cutting out what should be
The document feed rollers may be dirty/worn which is causing the paper to come into the scan area late causing your document cut offs. use a clean, lint-free cloth dampened (not moist) with water and clean the document feed rollers. Confirm they are dry then, try scanning multiple pages and see if they pull through without stalling. If they do, it's time to replace those rollers.
Aug 27, 2017 | Xerox CopyCentre C20 Black and White...
How do I do a password for the machine Xerox CopyCentre C128
Click on the link below and select to view the Xerox CopyCentre C128 owners manualm inside the manual will show you how to set the password
http://www.support.xerox.com/support/copycentre-c123-c128/documentation/enus.html
Dec 19, 2010 | Xerox CopyCentre C128 Black and White...
The error 03-544.00 of Copycentre C 35 ? What is this?
go to this link -- it wille xplain all error codes
http://www.support.xerox.com/support/copycentre-35/support/enca.html
kindly send feedback for my assistance -- much appreciated
Oct 30, 2010 | Xerox Office Equipment & Supplies
For document centre c250 fuji xerox: error code 062-380 or error code 062-386
Defective IIt/IPS board. Is very expensive. Call you local Xerox service number and ask them for part number 160K99811 and how much it would cost to get it fixed.
Aug 04, 2010 | Xerox CopyCentre C128 Black and White...
Copycentre c20 has open heat error message. How do I replace fuser unit?
The fuser unit for this machine can only be installed by a technician as the fuser unit itself is not for sale to consumers.
Nov 19, 2009 | Xerox CopyCentre C20 Black and White...
Our copier makes light copies.
Most likely, you need a new toner cartridge, part number 106R01047
Jul 24, 2009 | Xerox CopyCentre C20 Black and White...
Gives an error code 062-277
You will have to call in a xerox tech, it seems that one of the boards on the scanner is u\s
Apr 13, 2009 | Xerox CopyCentre C123 Black and White...
XEROX COPYCENTRE C20
u can find manual for this copier at the link below:
www.lostmydrivers.com
Jan 10, 2009 | Xerox CopyCentre C20 Black and White...
Xerox CopyCentre C118 Copier Logo
1,899 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
