Posted on Apr 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I used to be able to select the draft option when printing, but this seems to have disappeared. I am using an Epson stylus TX100 printer and my document is in Word 7. How do I get draft back?
Sandra Dunhill
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 50 Answers
  • Posted on Apr 12, 2011
Sandra Dunhill
Expert
Level 2:
Mentor:
Answers
50
Questions
0
Helped
31246
Points
136
You can set the option to print in Draft mode while in Word. Follow the steps below and see if it works for you.
1. Go to the MS Office button in Word at the top left of the screen.
2. Then click on Word Options button located to the bottom right of the Office Menu.
3. Select the Advanced Options at the left of the screen.
4. Scroll down and look for the Print Advanced Options
5. Choose "Use Draft Quality"
You can also set your printer's properties to print in Draft mode. If you've tried that and it doesn't work I would suggest updating or reloading your printer's drivers. The print drivers may have become corrupted.
I hope that helps.
Print head doesn;t move at all in epson stylus tx100
Anon, epson stylus tx100 print head doesn't move when turned on.
epson printer problems
2answers
My epson px660 is photocopying and printing double images
Try to print with disabling high speed option. Check the linear encoder. Clean it if dirty.
2answers
Why my tx100 printer can't work with vista
ISSUE : Epson Stylus TX100 is not working with VISTA Computer
Environment :
Printer : Epson Stylus TX100
Computer Operating system : VISTA
Analysis : According my understanding your printer use to work with different operating system like XP Home /Prof. etc But it is not working with VISTA
SOLUTION :
Cause of your problem might be : Software issue
To get the print out of printer your computer need to have a driver software on it. You can check the compatibility information written on the CD / DISK itself
Else you can also download the Compatible drivers from the following link of EPSON
http://www.epson.com.ph/epson/drivers/driver_download.htm?dc=1&mode=3&m=false&catid=4&pid=1373
or you can simply open www.epson.com
and click on Drivers and Support and select the printer -- you can easily download the drivers ...
I Hope it will solve your issue
2helpful
2answers
Epson Stylus TX100 printer Woeks but scanner not
It is a scanner as well, but you have to access the scanner through the software that came with it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
1helpful
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
3helpful
2answers
EPSON tx100 refuses to print - ink light on
ink light on? Check status monitor. Usually after jammed paper, printer trouble to recognized ink. Do change ink tank procedure, unplug and plug again ink tank.
Dark Prints
Does it have options, like normal draft, normal, best? Then use normal draft or draft option it will lessen ink usage. I think it is set to best setting.
I cant enlarge a photo copy on my Epsom printer TX100
While printing go to options before pressing print button. There choose size you will find your solution there. You can select printing sizes there.
k24674
ADMIN Andrew
ADMIN Andrew
