Hi my clothes are coming out with fluff all over them the blacks
look really bad how do i clean the filter or is there something else that i need to look at? regards Judith
Hi dear.
Basically you can check fluff filter otherwise you may need to have a technical assist. Fluff filter located on front LHS bottom corner of your machine.. Open plastic cover. Place small bowl under fluff filter area to collect about 2 Lt of water. Slowly turn fluff filter anticlockwise to let it drain remaining water in there.. Then remove it and check for blockage. ( Step by step You can get full instruction from your machine's user manual on cleaning and care section.) If that does not solve the issue you may call Miele to assist you or local repairer. I hope that helps.Thanks.
Some washing machines have a filter usually bottom right hand corner, you can clean this out.
They do say every once in a while to run the machine empty on a boil wash and add a little bleach or try some of these commercialised cleaners that remove limescale etc it cant do any harm.
Do this once or twice if its still bad the only thing i would suggest is to get a new one.
Clean you 'lint filter' - see your instruction booklet or if you don't have it google your washing machine model and see where the lint filter is and how to clean it. It's usually a small pouch on top on the steel drum that you have to slide out and clean.
Hope this helps.
certain materials give off fluff and some others seem to attract it. you can try putting in similar materials together and avoid mixing turkish bath towels, blankets and jackets and such clothes having fluffy lining with normal clothes. Also try selecting higher water level (overriding the automatic selection) manually. Once when i had fluff on clothes, it turned out to be tissue paper from my child's jeans pockets. After cleaning the filter bag, run the machine empty at maximum water level every week. Hope one of these will help solve your problem.
Hi, You can find the drain out valve by reverse tracing the outlet pipe you will find the hook like lever which is connected to the drain valve there you can find the threading type cover will be there just rotate in anti clockwise to remove from the unit just clean it and refix it properly
Sorry for the obvious.....
Fluff on the cloths is from the lint trap not capturing it from the air flow.
Air is passed into the clothes from the laundry room. It is heated and then passed over the clothes... then filtered air is forwarded to the outside exhaust.
If you are seeing lint on your clothes, then the air coming in from your laundry area is not lint free.
1. check the back/bottom of the dryer for lint accumulation.
2. Remove the lint trap and clean out the duct work.
3. Inspect all the flooring and areas around the dryer for dust/lint - and clean any that you find.
I believe that you will then have a clean and dry load.
The proceedure of cleaning described above should be repeated every 6 months or so....
-Jim
the lint filter is your problem needs to be cleaned out, the agitator which is the thing in th middle of the machine houses the lint filter the top should just pull off
you should clean filter after every load. If dryer is getting unusually hot (cabinet), then you may have a plugged vent line. Check where vent is on the outside and see if plenty of air is coming out of it. If not it is plugged up
