Our maytag washing machine model pav2300 aww rev 17
sounds like gears jumping and white residue under machine
what can I do to find where to fix this problem
gringing noise is never a good sign check the main bearing these are notorious for having bearings go and if it is bearing find a new machine its not worth fixing it is costs more then the machine is worth to replace
OK, this is a drive shaft issue. the gear case that the drive is connected to is malfunctioning. there may be a stripped gear or the clutch may need to be replaced.
It sound like you have a bad float switch and it is not reading the water level right.If it is filling and wont stop then a possible new water valve is in order:) The float switch is locatted under the top panel of washer
I would suggest Service Technician is cheaper than doing it yourself Bev007. It will save you headache too. Depending on the severity of the damage, you'll be working on the transmission attaching the shaft of the pulsator or agitator.
