Maytag MSD2655HE Side by Side Refrigerator Logo
Posted on Apr 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a water filter for a msd2655 maytag.Which one should I use?
John Tripp
Level 3:
  • Maytag Master 4,656 Answers
  • Posted on Apr 12, 2011
John Tripp
Maytag Master
Level 3:
Answers
4656
Questions
Helped
1679086
Points
14883
Your model requires the=> PuriClean II Model UKF8001AXX
Here is the page from the Service Manual=> PuriClean II Model UKF8001AXX
Should you require a user manual or Service Manual User Manuals Click Here=> Maytag User Manuals I was going to link your user manual but the site is down and has been reported automatically. And if you have other questions please ask me here at Fixya, Thanks, Sea Breeze
2helpful
Maytag msd2655 freeze work good,fresh food side not cold
HI TRY DEFROSTING ALL FIRST.MIGHT HAVE ICE BUILD UP AT THE BOTTOM.IF IT WORKS GREAT. IF NOT THEN FURTHER INVESTIGATION REQUIRED.SERVICE COND/UNIT.GOOD LUCK ALI
We just had a new RO Unit installed at our sink, and a line run to our Maytag fridge. The water filter is inside, at the top. We don't really need the filter anymore, as the RO water is more tha
Take the filter to the hardware store and get the necessary fittings (and maybe a short piece of tubing) to connect the in and out lines without the filter. Perhaps easier deal is a new filter which should NEVER become clogged on RO water.
1helpful
We are trying to replace the ice maker filter on a Maytag mf2557hes. Where is it located? Does this Maytag Refrigerator have a filter?
Maytag brand water filter removal and replacement:
refrigerator_maytag-filter.jpg Removing and replacing a water filter
There are two different types of Maytag brand water filters. Each one is removed in a different manner, depending entirely on where it is located in your refrigerator. There are two main locations. Select your filter location from the options below for specific removal and replacement directions.
  1. The upper right corner of the refrigerator compartment.
  2. In the center of the ceiling of the refrigerator compartment.
Bought a new Maytag side by side. Will not put out water. Tried the 5 sec on and 5sec off to flush the air out, still didn't work. What next?
Hi and welcome to FixYa, I am Kelly.
First off you need to make sure the freezer door is CLOSED and water filter is properly installed in the filter housing. Without a model number I can not tell you the exact location of the filter. There is a water lock out function of the water filter housing that will prevent proper water flow until the filter is installed correctly or removed completely. Also... there is a water tank / reservoir that has to be filled completely with water before you will see any water at the spigot. Please pass your model number so I can better assist you or call the Maytag Sercive Center so they can walk you through the initial set up procedure of your refrigerator. (They will also need your model number) Go to http://www.maytag.com and register your appliance before making the call.
1 (800) 344-1274 U.S.
1 (800) 688-2002 Canada
Before making the call check out this information about troubleshooting:
http://maytag.custhelp.com/app/answers/detail/a_id/110/kw/Water/session/L3RpbWUvMTI5ODY4MTEyNi9zaWQvam9CYWV5bms%3D
- After connecting the refrigerator to water source or replacing the water filter, flush the water system. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue to press and release the dispenser bar (5 seconds on, 5 seconds off) until a total of 3 gal. (12 L) has been dispensed. This will flush air from the filter and water dispensing system, and prepare the water filter for use. Additional flushing may be required in some households. As air is cleared from the system water may spurt out of the dispenser.
- Make sure the dispenser is not locked. Some models have a lock feature that deactivates the dispenser levers and control buttons. The lock button is on the dispenser front cover. This feature controls unintentional dispensing during cleaning. Press the Unlock or Locked button to reactivate the dispenser levers and allow dispenser function. You may need to hold the button for 2 to 3 seconds.
- If there has been a recent power outage or the power supply has been off for more than one hour, the power outage indicator (on some models) will disable the dispenser function. The dispenser display will read "PF" to indicate power failure. To use the dispenser, press and hold the "Reset" button for 3 seconds until you hear the beeps.
-A clogged or incorrectly installed water filter will reduce the water flow to the water dispenser. Check for a problem with the filter by removing the filter and operating the dispenser. If water begins to flow, then the filter is either clogged or incorrectly installed. A clogged filter will need to be replaced.
If the filter is clogged and you are not able to immediately replace it, leave the filter out so the water system is in bypass mode. With the filter removed, the water system will continue to operate, bypassing the filter, and the clogged filter will not cause slow water dispensing. However, in order to have filtered water, you will need to install a new filter.
All Genuine Maytag Water Filters retain beneficial fluoride and are NSF Certified for drastically reducing chlorine taste and odor, particulates, lead, mercury and cysts.
To ensure glass after glass of clean, refreshing ice and water, change your filter yearly or whenever the system light indicates.
about the filter:
http://assets.whirlpool.com/files/usr/animations/ANM000085.htm
The information above should get your water working. If not please listen for a solenoid buzz as you actuate the water in door function. No buzz either the dispenser is locked off or.... you have a valid warranty claim.
Thanks for choosing FixYa,
Kelly
Need to know which water filter to get?
You can buy the filter on link below.
http://buyitnow64.stores.yahoo.net/maukpuiirewa.html
Please rate 4 thumbs for the free answer
1helpful
Location of water filter on maytag model msd2351hew
Hi.The water filter is located in the upper right-hand corner of the fresh food compartment. You will need to turn the filter, counterclockwise, to release it form the housing.
Maytag refrigerator water dispenser not working
you may have dislodged a sensor or perhaps you may have blocked your water line somehow... im not sure about this specific model, but just try having a look at what you did and see if there are sensors around there.. and make sure u havent dropped anything in there wich may have clogged the lines... lets hope its not your solenoid that has gone, sounds unlikely though you never know
11helpful
Our Maytag icemaker stopped making ice suddenly after we changed the filter. It dispenses water only.
Does the water have a good flow ? Did you try putting the old filter back in ? Never change the filter just because a little red light comes on . Only replace when the ice cubes get small or the water dispensor flow gets slow . I have found new filters that were bad . Distributors make a lot of money for filters just because of that little red lite . Not just maytag , but all other brands also . Try pouring about 1/2 cup of water into icemaker . If it dumps the cubes but doesn't fill , replace the water valve . If it doesn't dump , and holds the cubes for a long period of time , replace the icemaker . Also , you may need to clean the coils of dust , lint , etc....
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
