Hello and Welcome to FixYa!
Error e00100 means that the card is corrupted or formatted for another
digital camera.Format memory card and see the results,Try to format the memory card using a card reader with the PC, if error still exists then it means the memory card is electronically incompatible and won't work The Kodak C310 uses MMC and SD cards and may be you are using SDHC memory card, In this case change the memory card,
I hope problem will be solved, if error still exists then contact to Kodak Cameras service providers.
I hope this solution helps you
Your token of appreciation in the form of Four thumbs and testimonial will be esteemed.
THANK YOU and Keep Visiting FixYa!
SOURCE: i have a kodak c310, trying to format the card and
The c310 will only accept SD cards up to 2GB.
You haven't said which card you're trying to use but the symptoms are typical of those encountered if you try either a larger capacity SD card (which go to 4GB maximum) or if you're trying to use a later SDHC (the HC means High Capacity) card. The c310 was designed and manufactured before SDHC cards were manufactured and is incompatible at the basic hardware level. SDHC's will fit inside as they have the same form as SD cards, but your camera is unable to use them.
If you have tried using the wrong card then all you need to do to fix the error is to replace it with a standard SD card not exceeding 2GB. In practice you'll find that your camera may have issues with some brands/models of 2GB SD cards but that it will work fine with any make or model of 1GB SD card. The smaller capacity card will also ensure that your camera does not become awkwardly slow in operation.
Hopefully I've answered your question; all I ask in return is that you return the favour by rating my answer.
SOURCE: I put in a new memory card and the camera shows
What is the capacity of the SD card you bought? You can only use up to a 1G card in that particular camera.
SOURCE: it says the memory card
The Kodak Z612 only accepts standard SD cards up to 2GB. As you rightly point ot the physical charactreristics are identical, its the internal format of the card that defines SDHC.
Standard SD cards use FAT - which has a 2GB limit.
SDHC cards use FAT32 - which has a limit of 32GB.
Stick with 2GB or smaller standard SD cards.
SOURCE: FILESYS ERROR E00100
Which size has the card?
Is the write protection enabled?
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
SOURCE: Trying to format screen says filesys error e00100,
Your Kodak camera can only work with a card that has a capacity of 1GB MAX anything more and it just wont work.
