The light from the projector flickers kind of like a regular bulb that's going bad.
Please help! ")
Thanks
I had the same problem before the bulb blew out. Is this just a precursor to bulb failure and replacing the bulb would fix the problem? Or is it a more serious problem that may cause a second bulb to blow?
Put the projector on a power regulator see more http://lamp-projector.com/index.php?k=power+regulator&c=3
I have the exact same problem, it comes and goes, but i noticed that
the screen was flickering more when the projector was tilted up a bit.
I shifted the cable from s-vhs to vga and now i dont have this problem so often anymore.
I also have the common problem that it sometimes wont start up when i power it on, or it shut down after a few seconds. It seems to be a loose wire somewhere, but i just give it a punch and then it starts..
Please dont forget to vote this answer was helpful
Many thanks
Many thanks
The projector is a InFocus LP70+.
I have the exact same problem, it comes and goes, but i noticed that the screen was flickering more when the projector was tilted up a bit.
I also have the common problem that it sometimes wont start up when i power it on, it seems to be a loose wire somewhere, but i just give it a punch on the head and then it starts..
Light was flickering before the bulb blew out. Will replacing the bulb eliminate the flickering?
I had the same problem and took the machine to be repaired. The problem was diagnosed as a power supply connection that was bad. It was repaired and worked fine for 4 months and now the problem is back.
GB
Our Lp70+ started to flicker a month ago. Not always, but from time to time. I was certain the lamp was going to die so I ordered a new one for 246 €. Just to realize that I have the same flicker with the new lamp. Tried it with two different computers (one with ATI graphics card and one with a NVidia graphics card. Power supply? Cable error? Who knows?
