The device is drained to the bone this should go away and boot after 30 minutes max. I'm assuming you are using the original blackberry charger using a charger that fits but doesn't match the voltage/amperage that the blackberry charger outputs you wont be able to get rid of the drained battery screen if your blackberry haves juice you can use a non-approved weaker charger but that screen means it needs the original....also the blackberry USB is lets the same amount of electricity
