We turn off the circuit breaker and if we turn it on and used it after we use it 2 to 3 hours it will display the F7 and bake push start alarm. The alarm sound is so irritating.
Please, help us what to do with it.
Thanks.
F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Thanks
