Echo Blower Nozzle Es 2400 Pb 200 201 2100 21001420561 Logo
Julianna Arthur Posted on Apr 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What kind of fuel do you put into an Echo PB201 Leaf Blower?
Charles Huckeba
Level 2:
Genius:
  • Expert 1,114 Answers
  • Posted on Apr 08, 2011
Charles Huckeba
Expert
Level 2:
Genius:
Answers
1114
Questions
0
Helped
322076
Points
316
The blower is a 2 cycle, so you run an oil and gas mixture. Here is the link for the owners manual.
http://www.echotool.ru/files/50_17_21-21G-00.PDF
How do i check spark on my echo leaf blower
You can take a spark plug tester and plug one end into the spark plug wire and the place the other end on the spark plug and pull the starter rope and see if there is a spark present. Hope this helps.
My echo leaf blower shuts down after a few minutes of operation, I have replaced fuel lines and Gas
I would also take the air filter element off and clean and reoil it. You may be pulling sufficient fuel, but if there isn't enough air in the mix, your leaf blower will stall out.
I would clean the air filter, and you may want to take the carb unit off and spray it out with aerosol carb cleaner. The carb cleaners are available at local auto parts houses, and it comes with a small spray tube to put on the nozzle so you can pinpoint the spray into the carb jets etc.
Also change your spark plug as they get fouled due to the fuel oil mixture..
best of success!
May 11, 2010 • Echo Garden
Echo leaf blower - cracked fuel line - how to solve? Is new tank required? If so, where does that come from? Any solutions?
If yours is like mine ... replace the hose. Get the hose at your Echo dealer or at any auto parts store.
What fuel mix do I use in an ECHO PB413H leaf blower
i have a leaf blower which uses leaded petrol but i would check your user manual and if you dont have one there allways is a copy of it online.
5helpful
Echo pb-260l won't spin up. replaced carb, plug, fuel filter and
i have aecho pb 260l backpack style leaf blower and it will not start. it turns over well and has spark and reasonably new fuel. any thoughts
Runs fine &then suddenly stops
IN the tank there is a intake tube on the bottem of that tube is a tiny filter. you can reach in and pull it out the tank enough to work on it.
It is clogged pull it off let it dry for a day and then blow it clean fron the gas line side OUT.
or echo sells tune up kits for 10 bucks at home depot. -Jeff Anchorage Small Engine.
Top Echo Garden Experts
john h
Ngoro
vince
Are you an Echo Garden Expert? Answer questions, earn points and help others
