SOURCE: technics sl-dz1200 parts
THEY HAVE THE PARTS AT PANASONIC.COM. THEY SHIP ANY WHERE....JUST TYPE IN MODEL#...
SOURCE: the platers arn't hard and heavy any more
Have you tried swapping out the platters? Sometimes this will fix the problem. Also, although VERY RARE, make sure you were sold the right platters with your turntables. I doubt they found a pair of copy cat platters, but ya never know!
You can remove them by just lifting them up and off. There is a magnet that holds them down, so if you encounter resistance, just tap the center shaft with a wood block, mallet, or similar. Don't hit it too hard, you just want to disrupt the magnetic force, and/or loosen the platter from the shaft (which sometimes gets stuck).
Other than that, I've never heard of this type of issue, and I repair these things for a living.
- DJ PRO LAB
www.DJPROLAB.com
SOURCE: How do I remove the platter on a sl-bd22 Technics
You will have to lift off the cloth on the platter section to expose two rather large holes in the plattr. Insert your thumb and forefinger, and pull up.
SOURCE: SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from [email protected]
