SOURCE: the adapter for the radio
what kind of radio did you get-if it is a new aftermarket radio it would come with a plug that you must wire to the aftermarket wiring harness you bought then if you got the correct harness it should plug into the Car- Metra has the correct harness it is part #70-1770
SOURCE: removal of radio
1. disconnect battery lead because of air bag sensors
2. pop off trim around shifter stick
3. remove center knob on the A/C panel. Remove phillips screw behind
the knob. This is the only screw that has to come out (in addition to
the 4 radio screws)
4. pull the a/c console forward. It's a tight fit but it's only held by
clips. This was the most difficult part for me because I didn't want to
break anything. It eventually released after pulling with constant
pressure.
5. pull the air vent assembly off around the radio. This is also a
tight fit, is only secured with clips. The radio face plate came off
with this piece.
6. Remove 4 10mm bolts at bottom of radio. I used putty on a 10mm
socket to help hold the bolt from falling down into the dashboard. Lose
these bolts and you'll easily add several hours to the job trying to
fish them out of the dashboard.
Hope this helps
SOURCE: remove dashkit
You need to remove the plastics around the radio area, they simply pop off. Unhook the plugs connecting the buttons. Then you'll have access to the radio, they are simply bolted in. Once you remove the bolts, there's a harness that plugs into the back of the unit. Also note that the SC has an amplified system, meaning you can't just swap the radio unit out, you'll need to change the amplifier as well. Depending on the year of your SC, you'll probably need to change the speakers as well. Most likely the amp you'll be putting will have more power than the stock unit and will likely blow them out.
SOURCE: to fit a bluetooth parrot mki9200 hands-free music kit
go to metraonline.com and your car then select kits choose the kit for your car and then hit product instructions. you should see radio removal procedures for your car dash.
