If you are talking about problem with your password You need to prepare: http://majorgeeks.com/download.php?det=5710
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
hope this helps
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive) Hope this helps
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
i noticed you said that this happens to all 20 of these hard drives have the same problem so if it cant find the hard disc make sure the leads from your ((motherboard to hard drive)) have secure seatings and are dust free or replace them IDE or SATA even the electrical extensions they could be faulty
lets get all of the details first you say you cant access the hard drive then the message cant be formatted how are you trying to format the disc what procedure???
actualy its not really da password that am worried about the problem is i cannot acess the hard disk itself it seems to have some kind of protection where i cannot format it;`it says cannot find hard disk, this a used hdd from an organisation
i even changed pc and cables and really confirmed it has somting to do with the hard drive itself. is there a way i can format it because it kepps on saying "this drive cannot be formated "what could be the problem that stops me from formating it. (it happens on all 20 40gb hdd even i change computers)
