Check to make sure phone is registering in network. Check a network is selected. Try the following.
APN & data settings
To set the Access Point Name (APN) and turn on data settings, follow these steps:
- From any Home screen, tap the Menu key.
- Tap Settings.
- Tap the Connections tab.
- Tap More networks.
- Tap Mobile networks.
- Tap Access Point Names.
- If available, tap the T-Mobile US APN (the bullet point fills with green). If not available, tap the Menu key, and then tap New APN.
Note: To reset your APN settings, tap the Menu key and then tap Reset to default.
- Verify and update the following settings for the Data APN:
- Name: T-Mobile US LTE
- APN: fast.t-mobile.com
- Proxy: <Not set>
- Port: <Not set>
- Username: <Not set>
- Password: <Not set>
- Server: <Not set>
- MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
- MMS proxy: <Not set>
- MMS port: <Not set>
- MMS protocol: WAP 2.0
- MCC: 310
- MNC: 260
- Authentication type: <Not set>
- APN type: <Not set> OR Internet+MMS
- APN protocol: IPv4/IPv6
- APN roaming protocol: IPv4
- Enable/disable APN: <greyed out unless there are multiple APN's>
- Bearer: Unspecified
- Tap the Menu key.
- Tap Save.
- Tap the desired APN profile you want to use. The bullet point fills with green next to the APN profile.
Manual network selection
To manually select the wireless network the device connects to, follow these steps:
- Tap Settings.
- Tap Network operators.
- Tap Search now.
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
Switch 2G / 4G
To change the band between 2G and 4G, follow these steps:
- Tap Settings.
- Tap Network mode.
- Tap one of the following desired band settings:
- GSM / WCDMA (auto connect)
- GSM only (2G only setting)
- WCDMA only
Turn on / off Airplane mode
Airplane mode turns off wireless connections. This allows you to use apps and menus, but not make calls or use the internet.
To turn on or turn off airplane mode, follow these steps:
- Tap Settings.
- To turn on, tap Airplane mode to select the check box. Tap OK.
- To turn off, tap Airplane mode to clear the check box. Tap OK.
