5 burners on the stove, one will not light, almost as if there is a clog in gas line. Other burners are fine...
Hello
Check the air mixture on that one and make sure is like the other ones, it should be a slide sleeve that rotates to adjust the air, and make sure that, no bigfire yellow tips when switch is on high.
Hope this help
Eddie Rentas
Tupper Lake NY
If its the burner that hase the intermitent timer on it
i have the same problem & I troubleshooted it.
if u take the cover off thier is a part on it that the rest dont have. its a red thing that rotates & thier are little contacts in it. for some reason thier is something that messed up inside it.
i took both mine apart & switced the guts & one of the little "boards"
is not working properly.
so im shure that is your problem
Here
is a tip that I wrote to give details about why your cooktop will not
spark to light the burners..
Cooktop
Range Stove spark ignition does not work
heatman101
Same problem...
We have power, we have gas, the burner cap is on correctly, but the electronic burner does not ingnite the burner.
THERMADOR GAS COOKTOP MODEL SGCS365RS 5 burners - all work but one (center). There is no smell of gas when we try to turn on the one which doesn't light. All the others light & we smell gas. Is it possible the line is blocked or something needs to be cleaned?
