SOURCE: How do I reprogram the fax cover sheet?
While holding down the start and stop button with two fingers,
pull the plug from the wall, wait ten seconds, plug back into wall while still holding the two buttons, after plugged in take fingers off that should reset the fax.
SOURCE: I have a Sharp UX 355l fax machine and I need to
Select FAX mode when you only want to receive faxes on your line.
The fax machine will automatically answer all calls on four rings and
receive incoming faxes
Press the RECEPTION MODE key until the arrow in the display
points to the desired mode
SOURCE: I need a manual for Sharp Fax Machine UX-355L
Search the Sharp USA website
http://www.sharpusa.com/CustomerSupport/search.aspx?q=ux-355l
Specifically:
UX-355L Operation Manual
fax_man_ux355l.pdf
If you need more help come back.Post /
thumbs / testimonial are
welcome!
Sounds like you may have a noisy phone line, incorrectly set transmission level or no filters installed if using broadband adsl service, also pick up phone is it free of any background noise or crackles? (tel phone company or cable problem if noisy)
In australia there is a service for test fax level across phone line called FOLDS (Fax online diag service) maybe your carrier have one too so you can test?
