SOURCE: Not able to send message
First you haved to format your unit and your memory card,by formatting your unit pls follow this simple step,press # *7370# you have to enter your 5 digit security code the default code is 12345. by following this procedure will solve all your problem,especially is WD2 series .hope it will help........
SOURCE: Nokia 5300 Wont Send Text Messages
i had the same problem. first try turning the phone off then back on and if it doesnt work after that then go into menu>optus>SIM Backup and turn it on
worked for me
SOURCE: Unsupported message type
hi. it might be some virus kind of thing tarnsfered to ur mobile from other. it may even comes as text messages. rate me
SOURCE: Week old phone has stopped sending texts!!
Take the sim and memory card out of the phone, then type in *#7370# and then it will say restore factory settings, say yes, then it will ask for a lock code, this is 12345 - the phone will reset and then you will be able to send messages again.
!!*Make sure you back up all of your contacts and pictures etc onto your memory or sim card otherwise it will get erased*!!
SOURCE: Delay in sending Text Messages with the Nokia E62
Just turn your message memory to Sim instead of memory stick.. it would become very fast. I had the same problem its solved now
