SOURCE: whirlpool duet washer model GHW9400PWO
Removing the Washer Top
Three screws secure the washer top at the back of the washer. Remove the three screws and lift the top from the washer.
Removing the Console from the Cabinet
Disconnect the Touch Pad/LED Assembly ribbon connector from the left
side of the Central Control Unit and release it from the wiring harness
brackets on the right side of the washer top
Remove the detergent dispenser drawer by pressing down on the release
tab at the back of the drawer and pulling it completely out of the
washer.
Once the drawer is removed, remove the screw in the recessed hole next
to the drawer opening. Release the tab securing the right side of the
console to the washer
Open the washer door and place a flat-bladed screwdriver into the slot
in the bottom center of the console. Push the console up to release
center console tab. Be sure the ribbon cable clears the cabinet frame.
Removing the Touch Pad/LED Assembly from the Console
The Touch Pad/LED Assembly is removed as a single unit and contains the
Push Buttons, LEDs, cable, etc. The buttons can be replaced separately
SOURCE: Front loader is making funny noises. It was
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
SOURCE: how to remove front kick panel on whirlpool duet washer
just pull out the bottom it will un hook,,
SOURCE: install boot/gasket for whirlpool duet sport F/L washer
You will have to take the front off the unit. Just watch and remember how you do it. The hard part will be putting the snap spring back on. There is a special tool we use that make it alot easy.
Testimonial: "no problem! thanks!"
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
