Motorola Mobility MOTOROKR T505 Logo
Posted on Jan 07, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi there, I have a motorokr 7505 bluetooth device for the car. Recently it will pair just fine with my iphone, but wont allow me to make calls when I push the call button. it will, however, allow me to redial the last number by holding the call button down for a full sec. Any ideas? Thanx a lot, Sarah
Eric Sutherland
Level 3:
Master:
  • Master 665 Answers
  • Posted on Jan 07, 2018
Eric Sutherland
Master
Level 3:
Master:
Answers
665
Questions
0
Helped
263270
Points
2023
2 Related Answers
Anonymous
  • 630 Answers
  • Posted on Dec 04, 2009
SOURCE: Can't answer calls using IHF1000 when paired with
Press the big blue button in the middle. It will take the call but you have to wait a couple of seconds. Don't answer the call with the phone though as it will not transfer to bluetooth (it's a sort of privacy option)
Anonymous
  • 1932 Answers
  • Posted on Nov 01, 2010
SOURCE: I'm having a problem with
Try to reset the system and then try pairing it again.When you reset all paired device to the speaker will be wiped off.start paring the speaker with your Droid x
To reset :
press and hold both Reverse and Forward buttons at the same time until speaker system resets.
Thank You
User manuals free downloads
Hi. I may be able to help you, but I will need more information. Specifically, which device are you trying to pair to your iPhone? I assume you're talking about Bluetooth, right? You can use Bluetooth devices with your iPhone, including headsets, car kits, stereo headphones, or an Apple Wireless Keyboard.
To specifically answer your question, I would need more information about what you are trying to pair with your phone. Note that the documentation that came with your device (headset, car kit, etc) should contain instructions. Is it a Plantronics that you're trying to pair by any chance?
Also, from the title of your post, it appears that you're trying find free manuals for your iPhone. You can access the iPhone Manual from this site: http://support.apple.com/manuals/
If that link doesn't work for you, just go to www.apple.com, click on the Support tab located in the bar at the top of the screen, then scroll all the way to the bottom of the page and look for Manuals under the Resources column in the rectangular "Support" box at the bottom. From the new page that opens up, select "iPhone User Guide -- For iOS 7.1 software." You can download the manual or simply view it. It is very long! Bluetooth Devices are located in Chapter 3: Basics, page 35. BUT, the manual doesn't really tell you anymore than what I've listed below.
Here are some basics, if that is all you're needing:
Turn Bluetooth on. Go to Settings > Bluetooth.
Connect to a Bluetooth device. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. See the documentation that came with the device for information about Bluetooth pairing. (For information about using an Apple Wireless Keyboard, there are different instructions.)
iPhone must be within about 30 feet (10 meters) of the Bluetooth device.
More basic instructions are here:
Return audio output to iPhone. Turn off or unpair the device, turn off Bluetooth in Settings > Bluetooth, or use AirPlay to switch audio output to iPhone. See AirPlay on page 34. Audio output returns to iPhone whenever the Bluetooth device is out of range.
Bypass your Bluetooth device. To use the iPhone receiver or speaker for phone calls:
Answer a call by tapping the iPhone screen.
During a call, tap Audio and choose iPhone or Speaker Phone.
Turn off the Bluetooth device, unpair it, or move out of range.
Turn off Bluetooth in Settings > Bluetooth.
Unpair a device. In Settings > Bluetooth, tap next to the device, then tap "Forget this Device." If you don't see the Devices list, make sure Bluetooth is on.
2helpful
I told my Iphone to forget a bluetooth device, how do I get it back because it won't pick it up on my phone anymore?
First thing you need to do is to go into your Bluetooth settings and make sure that your phone is set up to pair with a device. Next, make sure that the device your are pairing to your iPhone, is in pairing mode. After both of these steps are complete, the phone should recognize the device and you can complete the pairing process. Hope this helps!
How do I pair a RocketScience Tracer bluetooth?
    • 1How to Pair a Bluetooth Device With an iPhone On the iPhone, click on the "Settings" icon. It looks like a gear. Then press on the "General" button. Select "Bluetooth" and then "Turn Bluetooth On." The phone is now ready to be connected to the Bluetooth device.
    • 2 Connect the iPhone Bluetooth travel cable that comes with the iPhone-approved Bluetooth device into the USB 2.0 port on the computer. Do not plug it into the USB port on the keyboard.
    • 3 Connect the iPhone to the other end of the cable. The cable goes into the data connection slot on the bottom of the iPhone. There is another slot on the top of the cable into which the Bluetooth device should be plugged in.
    • 4 Wait while the computer loads to recognize there is something plugged into it. Either a screen will pop up or an icon will appear on the desktop to let you know that the computer is recognizing there is a iPhone plugged into it.
    • 5 Let the Bluetooth device charge with the iPhone for about one hour. You can tell when the device is fully charged by viewing the status light on the device. It will be an amber color until it charges completely. Once the charge completes, it will turn green.
    • 6 Remove the Bluetooth device and the iPhone from the cable that is plugged into the computer's USB port. Push the button on the top of the Bluetooth device. This allows the calls to now go through the Bluetooth device instead of straight to the iPhone.
3helpful
2answers
Can't pair to iphone 3g
Hi, the iPhone 3G definitely does work with bluetooth. In fact, I'm talking on a bluetooth headset with my iPhone 3G right now.
You have to put both your Southern Telecom Emerson Bluetooth Headsetand the iPhone in "pairing mode".
On your iPhone, click the Menu button, tap the Settings icon, tap the General icon, and then tap the Bluetooth icon. Make sure that 'Bluetooth' is set to "ON" and not "OFF". As long as you have this screen up, your iPhone is in pairing mode.
Turn your Southern Telecom Emerson Bluetooth Headset off and wait a few seconds. On your Southern Telecom Emerson Bluetooth Headset, press and hold and Answer/End button for Five Seconds, until a solid blue light comes on, which places the device in Bluetooth discoverable mode.
Now that both devices are 'discoverable', the Southern Telecom Emerson Bluetooth Headset will show up on that Bluetooth screen on your iPhone. Be patient as it might take a minute to appear. Tap on the Southern Telecom Emerson Bluetooth Headsetin the list on your iPhone, and then it will ask you for a passkey. The passkey is "0000" (without the quotes). After you enter the passkey, the Southern Telecom Emerson Bluetooth Headset will show up on the list with the word "Paired" next to it.
Now you're paired! Incoming calls will automatically be passed to your headset as long as your iPhone can find it nearby.
Good luck.
1helpful
Need instructions for connecting ear piece to iphone 4
Hi,to complete the look of a tech-savvy, iPhone-using individual, you must have a Bluetooth headset to accompany it. You can pair any Bluetooth headset with an iPhone. The Motorola HS850 is no exception to this. Both Motorola and Apple's Bluetooth set-up process is fast, so you'll be talking with people through your new Bluetooth on your iPhone in a matter of minutes.
Instructions
Charge the Motorola HS850 headset fully before attempting to pair. Usually, it takes two to three hours to charge the headset.
Press and hold the "Call" button (has a phone icon on it) on the headset for six to 10 seconds. The outside LED light will turn on indicating that the phone is in pairing mode.
Choose "Settings" on the iPhone homescreen.
Select "General," then "Bluetooth."
Select to turn Bluetooth on.
Wait for the phone to search for in-range devices.
Select theMotorola HS850 from the list of devices.
Enter the headset passkey to complete the pairing. By default this is "0000."
Have a nice day..
2answers
My blackberry bold phone does not locate my Plantronics VBH-300 bluetooth headset whilst trying to pair them. It was paired with a previous nokia phone,which I no longer have.
Hi,you will have to delete the previous paired phones first before you can be able to pair the blackberry phone with your blue tooth device.
You can use the below steps to know how to pair properly:
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Hope it helped.
Thanks for usingf ixya..
Have put bluetooth on but it wont paid with any
To your diappointment the Iphone cannot send photos, songs, or anything like that, yet. What you can try is restoring your Iphone and then see if you can pair it with your device. If that doesn't work, then it just means that the device you are trying to pair with it non-compatible with the Iphone.
7helpful
2answers
Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
2helpful
3answers
Bluetooth problems iphone
bluetooth on iphone is crippled somewhat.. you cannot for example connect to another phone or a computer like you can with other bluetooth enabled phones.. The bluetooth on iphone can only be used to connect to headset/sat-nav hands free kits etc at the moment.. maybe in a future upgrade they will relax this.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
