Question about Dometic NDR 1062 Refrigerator
Not getting 12volts to control board. Schematic shows 2 thero fuses, one on the vent pipe (OK), one that is in the that the wires run under the vent pipe close to the burner next to the refrigerator back. That fuse is open. How di I get to it, not obvious how to remove vent tube or access that area.@yahoo.com
    Top Expert:
  • Dometic Master
  • 10,591 Answers
That is a fusible link in bend metal holding it pull out and change make sure if using LP burners clean and good pressure if electric check stack for clog or if vent fans that they are working unit overheated
Posted on Dec 23, 2017
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: dometic RM2852 will not turn on
The dometic recall requires the installation of a thermal fuse from the DC terminal block to the igniter,  Originally it was a solid wire connection, and the recall replaced this wire with a thermal fuse imbedded.  On my unit the installer placed the fused wire too close to the burner sheet metal and, viola, the fuse blew (being thermal).  Camping World found the problem in 5 minutes and repaired it in another 10 minutes. $107.00.
Posted on Feb 21, 2009
Anonymous
  • 68 Answers
SOURCE: My fredge rm 2652 not working
You need to check your fuses on the fuse panel inside your coach. The frig will not operate on gas or electric without 12 volt power to the frig circuit board.
Posted on Mar 19, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: Dometic 2811 gas/AC refrigerator poor operation on gas mode.
Your gas valve is sticking. Could be a bad thermocouple.
Set it to come on, then with a screwdriver handle or something similar, tap,tap,tap gently on the gas valve to see if it lights.
Once it unsticks it should operate OK.
If it does not unstick, replace the gas valve.
Posted on May 26, 2009
Anonymous
SOURCE: RM2652 WORKS ON GAS NOT ON AC ALL FUSES OK POWER
HOW DO I REPLACE THE AC HEATER IN MY RM2652 DOMETIC REFRIGERATOR
Posted on Aug 02, 2009
I have a 1997 chevy lumina with 3.1 engine. im not getting 12volts on connestor a on the left side of icm i checked all fuses they look good.could it be the ecm or the ignition switch thanks.
im not getting 12volts on connestor a on the left side of icm i ????? ICM - ignition control module ? Has only one power wire - Pink connector 2 - terminal B , Gets B+ voltage from fuse ELEK /IGN 15 amp fuse located in the under hood electrical center #1
Aug 03, 2017 | Cars & Trucks
Why I have no power on 1996 geo metro fuel pump when I try to star it ?
Sep 28, 2014
too old, to post ...? seems not.
check pump voltage at the pump cranking.
then if that fails to be 11v.
then at the fuel pump relay, cranking, (the big pink wire is it)
FI fuses
and ig-coil fuse must be good.
and the CEL lamp glow key on, or ECU may be dead.(ask)
always test with a $10 volt meter,
voltages matter, test lamps were great back in 1950/60.
these cars love to have, like 6 or 8v on the way to the pump, due to rust on the connectors.
the meter shows this truth, and never a lamp.
Sep 28, 2014 | 1996 Geo Metro
Where is power window relay
the FSM covers this as does alldata.com
fuse 15 blown?>
here is free (Del Sol, is unique)
http://hondatech.info/downloads/Auto/Manuals/Civic/
they sell them at HONDA, and most auto stores.
ok , i found the window schematic.
there is no relay, well ,that you can unplug.
do you have 12vdc to the door motor,? are all dead.?all motors?
if all are dead the fuse #15 (10amps) is blown (top cause)
the schematic shows:
the fuse
5 switches to fail
then to the "power window control unit" PWCU
this controller runs all windows.
if the inputs are good to the controller and the motors are good and not jammed, then the controller is bad. PWCU
use a voltmeter at the motor that is dead.
then work back from there, to the controller,
part ID 15 here, shows the PWCU.
this page shows ALL controllers.
http://estore.honda.com/honda/parts/view-honda-parts-catalog-detail.asp?m=1994-del-sol-2-v-tec-5mt&sn=&b=B++1305&dl=#
this is typical of all cars you can look online at any time
and all cars. goggle "honda OEM parts"
Feb 14, 2014 | 1994 Honda Civic Del Sol
P0449 fault code on 2001 Blazer S10
EVAP Vent Solenoid Control Circuit Malfunction, should just need a Evaporative Emissions (EVAP) Canister Vent Solenoid/Valve.
first test and check the wiring and make sure that its 100% the vent solenoid before you replace it, follow the steps below. you will need a volt meter and ohm meter which is available at any auto or hard ware store.
Tips:Evaporative vent solenoid is located on the rear of the frame cross member behind the fuel tank.
1. Test the voltage at the disconnected Powertrain Control Module (PCM) terminal Key On, Engine Off (KOEO).
2. If 0 volts, test voltage at the canister vent solenoid White wire.
3. If 0 volts, test voltage at vent solenoid Pink wire.
4. If 0 volts at the vent solenoid Pink wire, test at the ENG 1 labeled fuse.
5. If the fuse is B+, test at the under hood fuse block C3 32 cavity Red connector terminal F3. Should be B+.
6. If terminal is B+, trace and repair the wire from the under hood fuse block to the vent solenoid.
Feb 02, 2012 | 2001 Chevrolet Blazer
1994 GMC P/U's cruse control no longer works. Appears no power. Checked fuses in panel but no fuse by name of ''cruse'' and all fuses OK. Need diagram or schematic and/or help troubleshooting.
Does your turn signals, high headlight beam work? Also, does the AC function through the dash vents and not the defrost vents?
My cruise control quit and I found it was the vacuum lines running to the servo.
Aug 28, 2009 | 1994 GMC Safari
2003 chevy silverado air does not blow through vents. Condenser works. Pipes are cold. Fan works. Modular (next to fan) repalced to get fan to work. Heater air conditioner controls under radio replaced....
The air vents are control by vacuum line and or linkage.
Listen for hiss or feel for vacuum leak under the dash,
Feel for broken linkage(s) that are close to the vents.
WORK BACKWARD if you have small hands to feel out where is the missing link.
Jul 15, 2009 | 2003 Chevrolet Silverado 1500
Does not heat. Heating element was replaced and
Check the following to address this issue.
1. A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
2. Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
If all checks out OK above, replace the main control board.
Jun 17, 2009 | Samsung DV328AE Electric Dryer
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
Whirlpool oven that does not broil
Nabril, looks like you have a thermal fuse in the broil circuit. Take your meter and on the control board go to connector P2-2, should be a blue wire. Pull the connector off and see if you have continuity from the blue wire to the red wire on the terminal block (where the cord connects) power off, wires off. If you don't have continuity, it's probably that fuse. If you do, the only other thing I would think it could be would be the relay itself. The schematic does not show the placement of this fuse. It could be on the back panel or under the main top. Check out the pic. Part number..3196548 Catriver..post back.
Apr 21, 2007 | Whirlpool RF369LXPQ Electric Kitchen Range
Dometic NDR 1062 Refrigerator Logo
67 people viewed this question
Top Dometic Refrigerators Experts
Sheldon Dedek
John Tripp
John Tripp
Paul G
Paul G
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
