Televison & Video Logo
Posted on Apr 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is my Samsung TV model code LE32A456C2DXXU ready for digital?
Basuki Jrobenk
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Samsung Expert 177 Answers
  • Posted on Apr 06, 2011
Basuki Jrobenk
Samsung Expert
Level 2:
Mentor:
Answers
177
Questions
0
Helped
69454
Points
522
Hello, jeanfbaker.
LE32A456C2DXXU is ready for digital ? answer is yes it is HD ready, its means support 1366 x 768 maximum resolutions, means capable of displaying high difinations (PS3, HD box) . And capabel a digital tuner , means capable receiving digital channels.
Remote control code for a 19"HD READY DIGITAL LCD
Hi Hazel,
The common codes used for Matsui TV are 098 and 178, however if these codes didn't work, please let me know the exact model number of your universal remote control to determine the right/other codes.
Kind Regards,
Mjsazon
1helpful
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
2helpful
2answers
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
1helpful
Picture has multicolours and is like a colour
Picture has moving multicolours and is like a colour ngative on the samsung digital tv. Model la37a450c1
1helpful
My warranty company cannot find digital board ID #BP9401853A
Here's a link to order the original Samsung digital board for this model (HLR4677W) from a major parts distributor:
Samsung HLR4677W Replacement Part Digital Main Board
Part is quite expensive, which may explain why your warranty company is unable to find one. :)
Is my tv digital ready?
the tv is about 4 years old, and has one componet input if im not mistaken. i'm pretty sure it isn't digital ready.
1helpful
Can't get digital tv channels.
The W1700 is HDTV Ready but it does not have an internal digital tuner, it only receives NTSC coded signals, not ATSQ/QAM coded signals. In order to see tv in HD you will need an external tuner with component or DVI output that you can connect to the monitors inputs.
Jerry
2answers
My samsung tv wont turn on, red light keeps flashing on the front.
i had this with my samsung and my mums instead of pressing red power button press either switch from analog tv to digital button or just press a number
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
