Question about KitchenAid Microwave Ovens
I just got a used K5ssww and when I tried it I didn't have the bowl snapped down at the back. It made a horrible racket and I tried it a couple of times before I found out it was snapped down at the back. The bottom of the beater has the white paint rubbed off now. It still hits a little. The woman I got it from had some trouble getting the flat blade off and it is a little messed up where you snap it on. When it is going slow it seems to be ok but if you speed it up it starts to hit a little bit. Have I messed it up? Is it ok to use if the paint or coating is dinged up on the bottom? I realize this is sort of vague but please help me!!! Thanks, Karen :)
6ya staff
SOURCE:
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: microwave touch panel is unhinged at the bottom
The mounting tabs on the control panel frame have cracked off most likely due to age, heat, or imperfections in the plastic.
If the tape idea doesn't appeal to you (*grin*) it will need a new control panel frame. That normally comes with a new keypad, but I would need the model number to be sure.
It is probably going to be referred to as the control panel in the parts list and it should run about $50 plus shipping.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Also, these units have mini-manuals hidden behind the control panel and they're very handy to use.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Normally you would unplug the oven from the wall, remove the 2 or 3 screws holding the grille in place, remove the screw at the top of the control panel frame, then CAREFULLY lift up and out to remove it.
Then you can mark and/or photograph the wires to be sure they all get back in the same place. Then you can see how the circuit board would come out and then go into the new control panel frame.
If you don't want to replace it, I would suggest that you get it squeaky clean and dry and use a small amount of household cement or Elmer's Glue-All (not super glue) on just the bottom edge, then temporarily use tape to hold it firmly in place until it has cured and dried.
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Posted on Nov 18, 2007
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Fan Stuck On.
You should have a one-year warranty on parts and labor and then a 5-year part warranty on the magnetron.
It sounds like the hood fan thermostat is flaky, or there may be a shorted relay or diode on the control panel.
But I would definitely avail myself of warranty service.
You can get your manual here: http://www.geappliances.com/service_and_support/literature/
GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 08, 2008
Anonymous
  • 52 Answers
SOURCE: Our Microwave keeps running unless we give it a whack!
Hi firstly to see if it is producing energy, buy some 5mm light emitting diodes from an electronics store. cut off the leads close to the plastic body.
place in microwave and put on cook for max 10 secs, if the led's light up you have microwave energy, shut off the oven as soon as they glow otherwise you end up with a mess.
If you have energy then your problem is most probably the door interlock micro switches which after time do not operate properly. let me know the results and we can go further.
Posted on Feb 23, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: samsung microwave door handle snapped off
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Posted on Sep 18, 2009
Anonymous
  • 85 Answers
SOURCE: Hi, This is Mike. My GE spacesaver xl1400 is
-thermal cutout
-fan/fan motor
-transformer
-capacitor/diode
-circuit board, triac or magnetron
any of these could be the culprit
any of these can be tested
let me know if you need further instructions
Posted on Oct 31, 2009
How can I keep the turntable from revolving when using a dish that is too large to turn?
Try removing the M/W turntable and placing a shallow bowl upside down centered over the rotating device. Then place your plate on top of the bottom of the bowl. The device will still rotate but will not be in contact with anything.
Nov 21, 2015 | Kenmore Elite Black 1.5 Cu. Ft. Convection...
I melted a plastic bowl in the microwave. How do I get the smell out of it
Good luck , but try a bowl of vinegar , hit power for about 40 seconds to warm it then let sit overnight, then wipe down walls and all interior surfaces with vinegar next day. Then wipe with clean damp cloth.
Some odors take a couple of times for this to work
Mar 29, 2015 | In Microwave Ovens
I only ned the bowl for my stircrazy popcorn popper. Is it possible to buy one and the cost please.
We can't sell you the bowl at Fixya as we only can help with instructions and so on. What I can help you with is where and who to contact about the bowl.
I believe your popper is made by WestBend. So you have a couple of choices. You can look for a repair shop that will have replacement parts. These are not that common these days but they are around. You can search on the net for them and I would talk to the store you purchased the popper from and ask where you can get parts. They may have a local repair depot that will be able to help. If that doesn't get you a source then you need to try Westbend.
Go to http://westbend.com/ and click on the support tab. Then click on replacement parts then Westbend and then popcorn popper. Select your model and it should now display all available parts. Unfortunetly the replacment parts tend to be power cords and covers so there may not be a bowl available for your model. It is still worth using the Westbend contact information and asking if they have one just in case.
Aside from other sources such as ebay or thrift shops you may not be able to find a bowl. And what you have to keep in mind is the replacement cost of the bowl plus shipping if you can find one. You may find that you will have to buy a new popper as it would cost less than getting the bowl.
Sep 18, 2011 | Microwave Ovens
I need a user manual and parts numbers. It works very well but needs a bowl and some blades
Can't refer you directly since you didn't include make and model number but once you have it, the link below is better for what you seek:
Kitchen manuals
Jul 09, 2011 | Microwave Ovens
After about 2 weeks of use, the microwave began to make a horrible buzzing noise from the "box" in the upper right hand corner on the back. It also smelled horrible. It then proceeded to stop working...
Two weeks? This is a warranty problem. The buzzing noise was probably either from high-voltage arcing or an overloaded transformer trying to drive a shorted component. The smell is from something electrical getting fried. Remember it; the next time you smell it, you'll know to pull the plug.
Oct 12, 2010 | Sunbeam SMW777 Microwave Oven
Difficulty cleaning Electrolux High Speed Oven
Most that say no oven cleaner have a self clean. If your does not. Take ammonia and wipe inside down and set a bowl of it inside over night. This will help a lot. One of my grandmothers tricks. It works great.
Please rate solution.
Sep 02, 2009 | Electrolux ICON Microwave Combination Oven
Has anyone replaced the Turntable Coupling?
You will need to remove the motor to get it off.
We have the full R-930AK/AW service manual for this model and have uploaded it to our site here to help you.
You will need the free Acrobat Reader to view or print it.
Here's the procedure:
1. Disconnect the oven from power supply. Remove the turntable tray, and the turntable support out
of the oven cavity.
2. Turn the oven upside down and remove one (1) screw holding the turntable motor cover to the base plate and take off the turntable motor cover.
3. Disconnect wire lead from the turntable motor.
4. Remove the two (2) screws holding the turntable motor and coupling mounting plate to the oven cavity bottom.
5. Turntable motor, Coupling mounting plate and Thermal protection plate bottom will be free.
Sep 25, 2008 | Sharp R-930AK Convection/Microwave Oven
Microwave Ovens Logo
42 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
