Mitsubishi VS-60719 60" Rear Projection Television Logo
Posted on Aug 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi vs-60719 my tv is turning on for about 10 seconds then turns off. and when it dosent turn off the picture has lines and you can barley see anything.
Anonymous
Level 3:
Genius:
  • Master 2,920 Answers
  • Posted on Aug 22, 2008
Anonymous
Master
Level 3:
Genius:
Answers
2920
Questions
0
Helped
934391
Points
7574
Yourpower supply is weak
I have the vs 60719
This set was made around 2001 and should have the self check feature. Unplug set and then plug back in and try to turn set on----if green power light comes on for a few seconds and goes off--ON the front of the set press and hold menu and input buttons together for several seconds and then release--------------power light should blink a two digit error code and repeat it several times.
1 blinks, 2 blinks a pause and then repeats(1,2 is no error found.)
Let me know what you find and comment here.
The tv turns on a couple seconds later back off. Cant keep the tv on....
try to check the power supply it has a shorted parts commonly transistors or leaky capacitors
Need anwsers asap! Mitsubishi VS-60719 60 in
Can you psot a picture of what the lines look like and I will try and help you out with it. Please reply to this same post each time. Thanks
No picture but have sound
Have a tech check for bad solder connections on connector GP on the main board and on the CRT G board connector SP. also to check solder on IC451.
Mitsubishi 6071 April 1994 NEED HELP!!!
these sets have bad connections in the picture yokes take the spekerr grill off and front cover move the wires around and see if the pic comes back be careful ok
Mitsubishi VS-60719 60" Turns off
replace the regulator and check for bad connections
Mitsubishi vs 60719 - Wavy bow in picture
Either a bad solder connection on your convergence module or a bad convergence IC. Repair costs will probably be in the $350-$500 range.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
