Samsung Galaxy BBSPHP1 Tablet PC Logo
Posted on Apr 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung galaxy tablet is frozen and the power would not turn off. What should I do ?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 14, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
10903
Points
6
Couldn't even turn mine off ... read up on this.
SIMPLE SOLUTION: Hold the power button down for more than ten (10) seconds. WORKED!!!!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 05, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
10136
Points
Take out the battery and put it back in
Anonymous
Level 2:
  • Expert 122 Answers
  • Posted on Apr 05, 2011
Anonymous
Expert
Level 2:
Answers
122
Questions
0
Helped
30033
Points
373
Hello, Please check round the body of the@Samsung you should see a resting botton on it that willenable you switch it off. Then press the resting botton again, before starting it again.
Kayla Bedlington
Level 1:
New Friend:
  • Posted on Mar 17, 2014
Kayla Bedlington
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
10136
Points
My Titan Tablet froze, so I tired to turn off the power... But the power off bottom got froze too..
Any ideas.. I don't want to take it in to get it fixed, cause well.. My weird friend sent me hentai link and I pressed on it..
Tim Digibrain
Level 3:
  • Master 846 Answers
  • Posted on Apr 11, 2011
Tim Digibrain
Master
Level 3:
Answers
846
Questions
0
Helped
1310062
Points
1356
If it keeps freezing there may be an issue with your logic board. can get the part at Galaxy Tab Repair and there is a guide that shows you how to put in the part at Galaxy Tab Repair Guide.
2 Related Answers
Muzahura Frank
  • 2071 Answers
  • Posted on Aug 18, 2011
SOURCE: SAMSUNG GALAXY TABLET NOT CHARGING OR TURNING ON
that must be a battery gone so low.. or even dead. did it just start? you could consider placing there a charged battery first check whether it powers before coming any conclusion.. like faulty charging system and like i said above, completely dead battery.
Anonymous
  • 32281 Answers
  • Posted on Jun 25, 2011
SOURCE: My samsung galaxy tablet is
It appears your Galaxy is faulty and it will still be under warranty. I suggest you take it to the supplier to get it repaired or replaced under warranty.
If you try to repair it yourself, you will most likely void your warranty.
Tablet wont turn on fully it freezes on the opening screen than just freezes there and wont turn on all the way what can i do to reset it
How to Fix a Frozen Samsung Galaxy Tablet [Solved] - Samsung ...
www.tomsguide.com/forum/id.../fix-frozen-samung-galaxy-tablet.html
2 days ago - 30 posts - ‎27 authors
I have a Samsung Galaxy Tablet that is completely frozen. ... If done correctly thescreen will turn black and automatically start the reboot process. ... Sure have, it won't turn off, swiping the front screen doesn't do anything. My Samsung tablet won't turn on! - Samsung - Android ...
Jan 17, 2016
My Samsung tablet will not turn on. - Samsung - Android ...
Dec 30, 2015
My RCA tablet won't turn on. What do I do? - Tablets ...
Dec 28, 2015
Help! My tablet won't turn on! what do I do?! - Asus ...
Apr 1, 2015
More results from www.tomsguide.com
2answers
I have a Samsung tablet 3 that the touch screen is frozen. I see where ppl are saying to turn off power, hold vol. down & power to get in reboot mode. I can't get mine to power off (touch screen froze) &...
Seems like the digitizer isn't working anymore u may wanna get ur tablet examined but to quickly turn off some tablets is to press and hold the power key till it shuts off and not lock the screen
1helpful
My samsung galaxy tab 2 is stuck mid-game , frozen , emitting shrill repetitive sound and I cannot exit, nor swtich off the tablet. please help
I just had that problem. Hold the power button down for at least 10 seconds or until it powers down. Froze mid game and emitted a shrill sound also. Hope this helps.
4helpful
My samsung galaxy tablet is frozen
Press and hold the power button for ~10 seconds.
128helpful
3answers
How to unfreeze my samsung galaxy 10.1 tablet
Hold the power button and the volume up button for 10 to 20 seconds :)
Galaxy tablet has frozen
Try the Reset button first - on the side...small hole. use paperclup with end extruded. Press in and hold down, turn unit on, release. If this does not work you will need to starve it of all power. no AC and remove the battery. Keep disconnected for at least two minutes. Reinsert the battery, fully charge, the turn on.
2helpful
32helpful
2answers
The screen has frozen in e mail and i cannot switch off or move to another function or do anything
If your Samsung GT-P1000 Galaxy TAB is frozen and unresponsive, press and hold [POWER ] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Menu
mode, select Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
