Pioneer Elite PRO-1140HD 50 in. Plasma HDTV Logo
Posted on Apr 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pioneer elite 2006 50" tv How can I change from
Loretta Northcutt
Level 3:
  • Master 736 Answers
  • Posted on Apr 05, 2011
Loretta Northcutt
Master
Level 3:
Answers
736
Questions
0
Helped
254375
Points
2334
You can't change the resolution on the television itself. You change the resolution on whatever you have connected to the television. Let's say it's a cable box or a blu ray player you've got connected to the television. First off you have to connect it to the television with a component (green, blue, red, white, red) cable or an hdmi cable. Then you make sure it is only connected to the television with either a component cable or an hdmi cable. This may sound ridiculous but there are some people that have their cable boxes and blu ray players connected to their televisions three different ways ( an hdmi cable, a composite cable, and a component cable) when they only need to have it connected one way.
Select the proper input on the television. Set the cable box or blu ray player's resolution to 1080i or 1080p (in the case of the blu ray player if it the tv will allow it).
I have a sharp TV and an trying to CD an Amazon fire stick. TV keeps responding...incomparable video signal...help
The stick is set to 1080p your sharp tv cannot show 1080p change it to 480p in settings , you will have to use it in another tv than is capable of showing 1080p, then just change it to 480p , then you should be able to use it on the sharp tv. You can then try to change it to 720p if it says the same about the signal leave it for 30 seconds and it will revert back to 480p
1helpful
How do i change from 480p to 1080p on my rca remote
You don't. The TV's resolution can't be changed. Only the signal resolution from the source can be altered.
The TV reports the resolution of the incoming signal before it is scaled. If you have a BD player you can see the effect of changing the resolution setting from 480p, to 720p, to 1080i, to 1080p 60, to 1080p 24. The last three (the 1080 resolutions) shouldn't look too different with a Blu-ray apart from movement because the native picture is 1080p 24 and the TV is simply converting it back to 1080p 24 for display.
Panasonic th 46pz80u
Yo don't. The TV's resolution can't be changed. Only the signal resolution from the source can be altered.
The TV is a fixed pixel device. The panel has a resolution of 1920x1080 pixels. The incoming video signal is scaled to fit that display. If the signal is 480i then it is deinterlaced to make it 480p, and then scaled up to make it 1080p. The amount of detail in the picture doesn't change. It's still a 480i image. It's just blown up to fill a 1080 panel.
960i is a funny resolution. That would be achieved by line doubling a 480i signal. But it's not one of the VESA HDTV timings. TTBOMK there's no Blu-ray or HD source that generates a 960i image. So even if you could generate it then the TV wouldn't understand what to do with it.
1helpful
TV was getting 1080p resolution Now 480p
Look in your menu for the resolution setting and change it back to 1080
1helpful
My Toshiba 55HT1U is showing 480p instead of 1080p. Why is it not on 1080p?
It is probably your video source. If you are using component video, some devices only output 480p.
Check the settings of your sources. The TV will display only what the device sends to it.
In most devices under a settings directory there will be settings labeled "Video" or "Resolution" Changing these settings to more appropriate High Definition resolutions should solve your problem.
2helpful
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
1helpful
I own an insignia 42"
The TV resolution is set by the video sources, not at the TV, in this case, your Dish network box is the one that is sending out 480p so the TV will display what it is being fed with.
What does Dish TV say aboyt this problem? How about the setup menu on the Dish network box?
Your TV works the same as your PC monitor, except that your monitor does not have a tuner, you adjust the resolution at the PC not at the monitor. 480p in = 480p display.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
My HDMI 1 input is set to display in 480p not in 1080p???
I think you have to change the settings in your HD box. Look on the diplay window of your HD box, if it says 480 there, thats where you need to change it so it will change then on your TV.
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
