Intel Motherboard Logo
Anonymous Posted on Aug 06, 2008
RunTIme Error 21 (XP Sp2)
Machine was fine yesterday - today - two annoying errors that WILL NOT go away. I have googled and searched but only find reg clean variety software that doesn't seem to be the issue. Running the 'free scan' provides a list of 'found issues' and none of them are really anything more than broken file paths. I did locate a google toolbar .dll and delete it via regeidt... but I am still getting the errors. Thoughts?, big heavy hammers?, advice for throwing myself from a nearby bridge?
TIA,
~Tami
  • 5 more comments
  • Anonymous Aug 06, 2008
    also tried spyware and regcare but both didn't work. getting double errors but at different numbers every time logged on. If close one can continue to work but otherwise it won't go away
  • 200Park Aug 06, 2008
    Have the same issue. When I run Hijackthis, I see three 04- entries of an alleged "Intelli Mouse Pro Version 2.0B" running from C:\Windows\System32\splm\ncsjapi.32.exe. I don't see that directory, so I'm suspicious that's what's causing my problem. If I remove if via Hijack, it just reappears w/the next reboot. No idea how to remove/resolve.
  • csrector5 Aug 06, 2008
    I'm having a very similar problem. Computer was fine last night, but this morning found the computer with an end task screen, and every time I shut it down and tried to reboot, once I logged on my icons would appear (no wallpaper) and two identical Runtime Error 21 codes would appear. The first string of digits would change with each reboot, but always had 49D2 as the final 4 in the string (017049D2, or 00BD49D2, etc...). The problem is, everytime I hit ok or close out the error code boxes, my screen goes blue, the icons reappear, and then I get two more identical Runtime boxes. I can't seem to navigate anywhere, so don't know how to proceed. Any advice would be appreciated...
  • mellowfellow Aug 12, 2008
    I also have this virus. I got it from a facebook wall post. There are some other forums discussing possible solutions - search on google and you'll find them. They best advice seems to come from Tech Support Guy Forum.
  • fydork Aug 15, 2008
    I have experienced the same 49D2 error problems others have posted which began when my son opened an e mail proportedly from his sister with no subject line. Sister denies having sent any message. Hmmmm? I could not get into safe mode. I could get to the Windows screen to begin safemode but once in didn't seem to have control of the mouse any longer.
  • Anonymous Aug 18, 2008
    once I have switched on and the desktop has come up, two dialogue boxes appear in sequence both with the same message "runtime error 21 xyzabc"
    (it varies). As long as I only close 1, it tends not to interfere with anything.
    I do find that if I close both, I get the momentary message
    "setting up personalised settings for c:\windows\system32\splm\ncsjapi32.exe", which disappears rapidly
    I have followed various current suggestions like starting in safe mode and searching on ncsjapi.. etc, to no avail
  • Anonymous Feb 27, 2009
    My computer won't go directly to prompt...it launches in safe mode..when I get to the files via run CMD...it won't let me delete. It says access denied. Please Help!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 15, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1373
Points
1. Boot up in "Safe Mode", but choose the one with "With Command Prompt"
2. Once you have the Command Prompt, change to directory by typing:
CD c:\windows\system32\splm + ENTER. Or d: or whatever your windows directory is called.
3. Change the attributes of the files in this directory not to be hidden:
ATTRIB *.* -H
4. If you go DIR + ENTER you will see 3 files
kbdsapi.dll
lmfunit32.dll
ncsjapi32.exe
5. DEL *.* + ENTER should delete them.
Your problems are over !
But go and delete the Registry entries, as in ATony's suggestion.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1481
Points
Find a folder called 'spl' in C:\Windows\System32
Rename it to splold
Reboot PC
Error message will appear to say the file cannot be found - click OK
Navigate back to C:\Windows\System32 and delete the 'splold' folder
Anonymous
Level 1:
Problem Solver:
  • Contributor 27 Answers
  • Posted on Aug 28, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
27
Questions
0
Helped
14311
Points
28
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
ahgqqq-5
Anonymous
Level 1:
  • Posted on Dec 07, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1373
Points
I have used system restore to remove this problem, setting computer to an earlier date. But you have to be fast when attempting to get to system restore or the runtime errors will freeze the screen. As soon as the icons load click programs, accessories, system tools and then restore, BUT YOU HAVE TO DO IT QUICKLY!
Anonymous
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Posted on Aug 09, 2008
Anonymous
Contributor
Level 1:
Welcome Back:
Answers
Questions
Helped
1373
Points
Ok, bit of a compilation of some other I have seen but it worked for me. First, switch off system restore, then boot up in safe mode. There were 4 places I found the offending file, which on my computer masqueraded as an Intelli Mouse file (whatever that is). First on a simple search, for *japi*.* files where it shows up as ncsjapi32.exe, it says its in System32/spml folder but that folder doesn't show up in explorer, there were also 2 other files in the folder, so do a search by date for the last week and you will find all 3. Second was using (yes another program to download) HijackThis, which shows all the open programs, sort of like a control Alt Del, but better, and gives you the option to delete the open programs under "fix it" in the bottom left. The third place was under the start menu, and "run" any type in MSCONFIG, where under the start up programs it again shows up. And 4th, again in start "run"under the "regedit"under HKey current users/software/microsoft/windows/currentversion there are run and runonce and it shows up in both.
So have all 4 open, then unclick the program in the configsys, so that it doesn't automatically start up, the deleted it in the regedit, and the hijackthis (sometimes 2 or 3 entries here so don't be fooled), and on the search (plus the two other files that were in the same folder & the folder). Then reboot again in safe mode.
If it seems to have fixed it, check all the above places to make sure they are all gone. Hope it works, if not sorry, it did for me
Tony
I am using Sony vaio S Series - VPCSB36FG. I keep getting a runtime error message when Google Chrome is running.
Go to www.google.com and in the search box type "download google chrome" (without the quotes). Download and install a fresh copy of Google Chrome from Google Chrome's website without losing any of your bookmarks.
When I logon to my computer, 2 little error messages come up with the same message: Runtime error 21 025D49D2. I can exit out of one of them, but if I try to exit out of the second one my screen loses...
Having Problems With Error 21?
Cause: Error 21 takes place when the system is misconfigured or its essential files are missing. Such problems occur when a PC is not maintained properly and has accumulated many critical issues that require immediate repair.
Solution: To repair Error 21 correctly, download and install the repair tool below. This tool was design to successfully diagnose, find and fix the problems on your computer.
http://www.restoreguard.com/p/error-21.html?keyword=Error%2021&gclid=CKXWrq7il6UCFS9e7AodYkPWHw
I found this by google.com searched "run time error 21 025D49D2"
it came up with run time error 21....
click on this link above...
good luck...
1helpful
Error R6002 floating point not loaded
try using windows 2000 or windows xp sp2 compatablity mode for the executable file that causes the error
Runtime error r6002
It's a Virus called W32/Parite-B
Here is how to remove it.
2answers
No access to the inbox the code error is 21
There are many reasons for experiencing a large selection of computer error messages; if your pc has displayed a runtime error 21 in recent days, don't despair. Understand that most computer problems can be readily straightened out even if you happen to be a beginner. Keep reading this quick report and i'll show you a convenient and successful way to solve this annoying problem with errors.
But first, it is important that you find out the root of these problems. Very commonly in cases like this, your windows registry comes into play - this is the location where windows monitors what takes place on your pc. It maintains a database of your software and hardware installations, and additionally, the links to files that run these applications. Quite often, a fragmented link or corrupted registry can be the reason for a runtime error 21 and an assortment of other issues, which can include slow response, lock-ups, and .dll errors.
Other reasons for having runtime errors include the incorrect loading or unloading of software, the incompatibility of various software applications (when there are many programs installed on your computer), infections with viruses and spyware, and other. To sum up, any or all of these can lead to broken or missing links in your windows registry, thus leading your windows to display all of those inconvenient error alerts, and sometimes more alarming problems.
There are many methods you can use to solve these problems; the thing is that not always do you know which application(s) may be corrupted, or which particular corrupted registry record(s) might be at the root of the error message. In that case, and especially if you are not a computer expert, there are two courses of action: hire a specialist (this is the expensive way to go), or download a professional registry cleaning software.
A registry repair tool is a program which instantly scours your pc and reveals an assortment of computer errors which commonly appear; this useful tool goes beyond just finding these irregularities, it quickly works to fix them and improves the speed and functioning of your pc. Anytime your computer comes up with a runtime error 21, it is advisable to install one of these utilities; the bulk of them permit free pc scans and a certain number repairs at no cost. Now's your chance to eliminate this error in just a few clicks.
Jul 01, 2009 • Yahoo Mail
1helpful
Runtime error resolution needed
Since our operating system is Vista I suspected it was related to this. I went into properties for the game and changed the compatibility to Windows XP and it is working fine now.
2helpful
5answers
Phillips SAA 7130 Video Caputure Card Error
In win XP right click desktop. Click properties. Click settings tab. Change screen resolution,as necessary, to solve problem. May also need to change color quality. Good luck.
3answers
Runtime error pop-up
Solution:
1. install Internet explorer version 6 or 7
2. install service pack 4 if it is Windows 200,
3 install service pack 2 if it is Windows xp
4.install the windows updates up to date
definetly will fix the problem
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
