The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre.
get estimate before you decide. It will be good to have it checked at the Nikon service as you do not have to run around for spares.
SOURCE: nikon d40
I had exactly the same problem, i tried everything,battery out, sd card out , lens off etc...nothing worked.Completely by chance and irritation i repeatedly pressed the shutter butten over and over
( without the lens attached ) till it didn't react at all.On my LCD i got a normal menu so i put the lens on and bingo it was fixed, still works fine.I think maybe the shutter was out of alignment.
Hope this works for you.
Olly
SOURCE: Error. Press shuter release button again
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
SOURCE: nikon d40x camera not working
The camera has a bad shutter or a bad sequence plate motor .
If you need help further contact
Berrie Smith Camera Repair
SOURCE: D40 "Error: press shutter release button again." Nothing happens.
Our friend photosubba is just right. I've got a friend who has a D60, and I just fixed the same problem. Only else thing to do is to put a little (LITTLE) quantity of oil on it - be careful for excess of oil not to eventually get inside the deeper parts of the camera and leak onto otics or electric circuits.
