You may try some file recovery program to scan the usb and recover the files.
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
Your files may deleted from your USB hard drive. you can recover your files deleted from USB flash drive. if you have not overwritten new files into your usb flash drive, you have great chance, if you have, you can recover part of them.
here is a guide helps you recover deleted files step by steps.
http://www.dr-fone.com/articles/usb-flash-drive-file-recovery.html
All right! Based on my experiences, there
are two ways to go for you:
1). Try to show these hidden files back
like this:
Start => Run => Type in "control
folders" and press "OK" =>Click "View" and hook "Show hidden files and
folders"=> Press "OK".
2). Try to recover these inaccessible files back for free with the help of a
file data recovery freeware here:
http://blog4mark.blogspot.com/2012/12/deleted-files-recovery.html
Next time, you should never save the needed
files on only one hard drive.
Try to look your USB drive status in Disk Management, after connecting it to your computer.
If its showing 'RAW', that means your USB is having file system
corruption and needs to be formatted. Moreover, you can go for the 'View
Show Hidden File and Folders' to see if its not mark as hidden.
If none of the option helps, using file recovery program is the only way that can helps you to get your stuff back.
P.S.: Avoid using USB till you successfully recover the files as using
it further might permanently delete all important files from it.
For recovery software, I bought one before, cost me 49 bucks but working very well, and good thing is that it's one time payment and then it allows me to use forever. Take a look if you do not mind paying 49 bucks to get back your pictures. http://www.restoredeleteddata.net/
If your files are not showing up on a USB flash stick, you can try to recover them with software like:
http://download.cnet.com/VaioSoft-Recovery-Manager/3000-2094_4-10286449.html?tag=mncol;1
It should also work on SD, SDHC, memory stick (Pro, Duo), multimedia cards (MMC), Xd, and other common camera card formats.
Please leave feedback if this was helpful. Thanks.
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
hope this helps you
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps you
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
