Mtp see the below list
The listed Flash codes are pretty standard and are applicable to powerchairs only not scooters:
1 flash User Fault (do not touch joystick) and turn back on
2 flashes Battery Fault Recharge batteries or replace
3 Left motor fault check connections or replace
4 Right motor fault check connections or replace
5 Left park brake fault check freewheel lever or brake connections
6 Right park brake fault check freewheel lever or brake connections
7 Remote fault check connections and wiring replace remote(joystick) (Check cable to the joystick unplug connector at rear of chair and plug back in then try turning on to see if you are getting same code)
8 Controller fault Check connections and wiring replace controller
9 Communication fault check cable replace (almost same problem as 7) try same fix if doesn't work joystick will have to be replaced
10 and 11 are unusual and will not be seen if at all
Hope this helps you
