If you are asking how to download to a computer file or a
storage device, there is not a way without a major modification to your
hardware (commonly known as a HACK to the device). Brother did not include a
way to download from memory to a computer file.On the other hand, if you want to print what you have on the
LCD screen you are typing in display mode. There are 2 typed of display modes
(Line by line, and Auto) The way to print in display mode is;
To determine what mode you are in, on the right side of the display you will see the operate section (see attached diagram) . If the triangle is pointing up you are in "Auto Return", if it is pointing down you are in "Line by Line" mode. If you don't see a triangle it should type as a normal typewriter (each letter as soon as you type it). To toggle through the modes hold the ALT key and press the OPERATE key. The keys that are activated by the ALT are color coded (same color as the ALT key) and are across the top of the keyboard.
