Are you looking for a professional and easy way to convert your Blu-ray movie to 3D video for playback on your computer or your big screen 3D TV? Then you will definitely to have a look at DVDFab
2D to 3D Converter. 2D to 3D Converter works with Blu-ray Ripper and can convert Blu-rays to 3D videos in AVI, MP4, MKV, M2TS, or TS format. Next is about the detailed how to.
2D Blu-ray to 3D Video>Step 1: Open Blu-ray Ripper and load in source movie Since 2D to 3D Converter doesn't work alone, we need to open Blu-ray Ripper to convert Blu-ray. After that, choose a mode that 2D to 3D Converter supports. Here we choose "to M2TS" as example. Then load in the source movie the same way as in Blu-ray Ripper. After the movie is opened as source, we'll see the following screen, and we can set subtitles, audio tracks, and profile for output title by passing when necessary.
2D Blu-ray to 3D Video>Step 2: Trigger 2D to 3D Converter, and set output video effect Now we need to trigger 2D to 3D Converter, just check the 2D to 3D box, which is the incarnation of 2D to 3D Converter in Blu-ray Ripper. After that, go ahead to freely set the output 3D video effect.
And the Video Effect Settings windows are as follows:
Customize 3D Format, Video Frame Size, Visual Depth, etc.
Resize Source Aspect Ratio, Frame Resolution, etc.
Crop play region manually or automatically.
2D Blu-ray to 3D Video>Step 3 (Optional): Customize parameters for video/audio format, and much more If you like, you can click Edit button on the main interface to change the default values of video/audio parameters and many default settings in the below screen.
2D Blu-ray to 3D Video>Step 4: Start to convert Blu-ray to 3D If you're ready, hit Start button the main UI to trigger the converting process. During the process, following windows are available for you to monitor the detailed progress, preview the source movie, and set auto shutdown for the PC when process completed.
After tens of minutes later, you'll get your desired 3D videos. OK, just a matter of 3 or 4 steps, and you'll finish 2D Blu-ray to 3D video conversion easily and quickly.
