HP PSC 1410 All-In-One InkJet Printer Logo
Posted on Apr 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My HP PSC 1410 printer giving error E and Check Cartridge red light blinking. I have replaced black cartridge with new one but same error. HP Print Diagnostic Utility shows it as Pen Failure. What does it mean? Is there any way that I can find out whether color cartridge is faulty & replacing it will solve the issue?
Clive Gray
Level 3:
Genius:
  • HP Master 1,479 Answers
  • Posted on Apr 02, 2011
Clive Gray
HP Master
Level 3:
Genius:
Answers
1479
Questions
Helped
291063
Points
4728
I found this searching our previous solutions fo this problem
http://www.fixya.com/support/t1037900-hp_psc_1410_when_switch
New black ink cartridge installed.printer is not printing properely since then.cleaning option from solution center performed.No change.print cartridges making hitting and rubbing sounds from inside the...
It appears that it has carriage stall problem. Please speak to tech support, so that if it is a hardware issue, and if the printer is in wty, then it could be replaced .
3helpful
2answers
HP printer PSC 1410 ALL in one printer showing "Check print cartridge" error
This eror usually mean that the printer cartridge has not been installed correctly. Try re-installing the cartridge. This error can also be generated by a logic fault within the printer.. if this is the case, replace the printer.. trying another new cartridge can be expensive so try and get a second hand cartridge, maybe from a friend and try that one.. Otherwise, replace the printer..
Hp psc 1410 printer error message
I fixed the problem I was having by re-installing the program, which then told me exactly what the problem was. It was the color cartridge.
I then put a new cartridge in and it worked!
3answers
Cartridge
did you do a clean cartridge and re alignment first?
http://tinyurl.com/6qcpgy
7helpful
Check Printer Cartrige
my printer is
HP PSC 1410 ALL IN ONE PRINTER
ERROR MESSAGE
1. CHECK PRINT CARTRIDGES
I AM REMOVE THE OLD CARTRIDGES
THEN NEW ADDED 21,22 CARTRIDGES
THEN NEXT ERROR MESSAGE
HOW TO SOLVE THE PROBLEMS
2answers
Hp psc 1410 all-in-one printer not printing
What is not working? The printer or the cartridge? If it's the cartridge, try this. fold a paper towel in 4ths, dampen it and place on a flat surface. Blot the cartridge several times on the towel. You should get blots of black with the black cart. and three colors with the color or photo cart. If not... replace. If the printer carriage just won't move and you're shure you have power.. time for a new printer.
8helpful
3answers
k24674
Grand Canyon Tech
Grand Canyon Tech
