Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Posted on Apr 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I've got a side by side Whirlpool refridgerator. The Water Filter status light is not indicating. What could be the problem and solution?
John Tripp
Level 3:
  • Whirlpool Master 4,656 Answers
  • Posted on Apr 02, 2011
John Tripp
Whirlpool Master
Level 3:
Answers
4656
Questions
Helped
1679033
Points
14883
There are several pages that explain dispenser programming. This is on page 10 of the owners manual.
Water Filter Status Light (on some models)
The water filter status light will help you know when to change
your water filter. When the water filter status display changes from
"GOOD" to "ORDER," this tells you that it is almost time to
change the water filter cartridge. Replace the water filter cartridge
when the water filter status display changes to "REPLACE." If
water flow to your water dispenser or ice maker decreases
noticeably, change the filter sooner. The filter should be replaced
at least every 6 months depending on your water quality and
usage.
After changing the water filter, reset the status light by pressing
and holding the FILTER button for 3 seconds. The status light will
change from "REPLACE" to "GOOD" when the system is reset.
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the covers from the O-rings. Be sure the O-rings are
still in place after the covers are removed.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See "Water and Ice Dispensers."
Water Filter Status Light:
The water filter status light will help you know when to change your water filter.
When the dispenser control panel's water filter status display changes to "ORDER," this tells
you that it is almost time to change the water filter cartridge.
Replace the water filter cartridge when the water filter status display changes to "REPLACE."
The filter should be replaced at least every 6 months depending on your water quality and usage.
NOTE: If water flow to your water dispenser or ice maker decreases noticeably, change the
filter sooner. After changing the water filter, reset the status light.
Details:
Pressing and holding RESET FILTER starts the 3 seconds countdown. Using the dispenser
cancels the countdown AND no dispensing is permitted. The number '3' blinks 3 times and the
'invalid' tone sounds 3 times and user has to release both the pad and the button and press
the button again to start it over
After 3 seconds, the BLUE WATER BARS in the Icon flash and an audible tone sounds 3
times. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the
display screen. See figure 16.
Note: Users can reset the filter status at any stage.
If you should need the complete and exact model number and manual with parts manual you will need to enter the Model Number here=> I've got a side by side Whirlpool refridgerator. - sea_breeze_132.jpg/images/sea_breeze_132.jpg" alt="sea_breeze_132.jpg" class="h_mi" /> Manuals, Guides and Instructions Please rate this solution, Thanks, Sea Breeze
User manual click HERE
How to get alarm to stop blinking after replacing water filter
Here is a list of refrigerator manufacturers and how to reset the filter change indicator light:
Amana- Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire- Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric- Press and Hold the Reset Button for around 8 Seconds.
HotPoint- Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air- Press and Hold The Water and Lock Buttons until the Water Filter light flashes.
Kitchen Aid- Press and Release the Light Button 5 times Quickly.
Maytag- Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung- Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool- Press and Release the Light Button 5 times Quickly.
After i change the water filter de button of water still red
The water filter status light, located at the top of the refrigerator
compartment, will help you know when to change your water
filter cartridge.
Style 1 - Standard status light (on some models)
When the water filter status light changes from green to yellow,
this tells you that it is almost time to change the water filter
cartridge (90% of the filter life has been used). It is recommended
that you replace the base grille water filter cartridge when the
water filter indicator light changes to red OR water flow to your
water dispenser or ice maker decreases noticeably. See
"Changing theWater Filter Cartridge" later in this section.
After changing the water filter cartridge, reset the water filter
status light by pressing the light switch 5 times within
10 seconds. The water filter status light will change from red to
green when the system is reset.
If you need Adobe Reader Click=> Adobe Reader X (10.1.0) (50.25 MB)
If helpful please rate this solution, Thanks Sea Breeze
Click Photo Below for User Manuals
How do you reset the water filter light on Model # ED5LHAXWQ00, Serial # HR02227866?
Hi, I found this handy guide:
Amana Refrigerators - Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire Refrigerators - Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
HotPoint Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Kitchen Aid Refrigerators - Press and Release the Light Button 5 times Quickly.
Maytag Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung Refrigerators - Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool Refrigerators - Press and Release the Light Button 5 times Quickly.
Rich
Refrigerator Repair Meridian
Western Appliance Repair
2helpful
I am replacing the water filter how do I reset on the outside door
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Thanks, Sea Breeze
4helpful
Red light stays on after changing the water filter and running about 2 gallons through it
Light (select models)
To Reset Indicator:
successfully reset.
Change filter light
To Reset Indicator:
successfully reset.
Sea Breeze
Changing light after installing new water filter
(select models)
To Reset Indicator:
• Press and hold both the LOCK and WATER
successfully reset.
Whirlpool gold side by side 2006 defrosting
temperature gadge must have been bumped, everything is working right now. Thanks
No power to control unit in fridge
Turns out we had a bad control board. One of the coponets was blown and it had to be replaced. $400.00 and its good as new.
4helpful
2answers
Water Filter Indicator
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
