Lexmark X7675 Wireless All-in-One Printer Logo
Posted on Apr 02, 2011
My Lexmark x7675 all-in-one printer scanner bar will not go all the way to the right. it goes about 1/4 of the way then returns and sounds as if the belt is slipping. Is there any way to adjust the travel on the scanner? This problem started after a hinge broke and I took the scanner bed off to fix the hinge.
5 Related Answers
Anonymous
  • Posted on Jul 03, 2008
SOURCE: clicking nosie from scanner bed on epson cx5800f
I had a similar problem, the scanner bar was stuck to the far left side. Here's how I fixed it:
1)Unplug the printer, disconnect any cables/phone lines to it.
2)Lift up the entire scanner bed housing(you will see the printer ink cartridges).
3)Locate the access patch (approx 1 cm x 1 cm square) along the left edge of the scanner bed housing(this is the side that closes in, next to the keypad buttons).
4)Using a small knife blade, peel off the patch from the corners and edges(it's sticky. Save it, you can stick it back over the hole when you're done).
5)Stick a pen through the access hole, and push the scanner bar to the right, approximately 2-3 inches.
6)Now, close the scanner housing, plug in the printer, and power it on.
It should reset and re-calibrate the scanner bar. If it doesn't, repeat steps 5) and 6) a couple times, until the printer correctly performs calibration. Then, you can put the sticky patch back over the hole, and you're ready to go. Hope this helps!
JenCluse
  • Posted on May 24, 2010
SOURCE: X7675 Aio Wl USB Adf 32/27PPM Ocr Dir Prt Pbridg Dplx All-In-One Printer: My lexmark x7675 can not download scan application...
No solution here - just confirmation. Mine say that it (the scanner) cannot save files to my hard drive, that it is full. That's far from true, but to a dumb accessory a locked target folder/directory will look like a full disk. Does anyone know where Lexmark parks it's temporary files? I've looked in all the usual places on my Mac, and can't find anything yet. (I have previously found a Brother parks it's initial scans, before you save them, deep in a normally inaccessible corner of the System folder.)
Anonymous
  • 1087 Answers
  • Posted on Jun 29, 2010
SOURCE: Lexmark x9350 will not copy or scan.
Great job on trying to do it both ways, scanning and copying. Try to refresh the printer by uplugging the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Make sure other end of the power cord is plugged in straight to the power outlet in the wall, bypass any surge device or power strips. Plugged the power adapter back in the printer after 30 seconds. It should automatically turn on. If not, press the power button. Try scanning and copying again. If problem persists, I strongly suggest you contact Lexmark Technical Support to further investigate the hardware problem in the printer. Hope I can assist you more on this.
Anonymous
  • Posted on Aug 28, 2010
SOURCE: No support for Lexmark X7675 on linux (ubuntu 9.04)
http://support.lexmark.com/index?locale=en&userlocale=EN_US&productCode=LEXMARK_X7675&page=recommendedDownloads&segment=DOWNLOAD#2
Anonymous
  • 82 Answers
  • Posted on Mar 05, 2011
SOURCE: broken hinge where do i
You can download the Manual to dis-assemble the Printer and purchase Parts for your Printer fro the below link:
https://parts.lexmark.com/wpo-catalog/US_en/search/data_type:model/machine_type_model_id:782
Please let me know if I was Helpful...
Direct me in use of scanner to computer on Lexmark 7675
You may refer to the Lexmark X7675 User's Guide. If you are using Windows, your User's Guide is available at Start -> All Programs -> Lexmark 7600 Series ->click on User's Guide. You can also download it for free using this link. Lexmark 7600 Series User's Guide.
How will i install my lexmark x7675 printer to my PC so that i can print?
I dont; have the book for my printer, lexmark x7675; I NEED HELP TO INSTILL IT
2answers
2answers
Have lexmark x7675 installed factory new cartridges still reporting out of ink
Hello. The cartridges may not be seated properly or just needs cleaning. Remove the cartridges from the printer. Make sure the protective nozzle tape is already removed. Wipe the nozzles of the cartridges using a damp paper towel. Unplug printer from power source, plug it back in after 10-15 seconds. When the printer's ready, reload one cartridge first. Close the cover, check if "out of ink" message is displayed. If not, proceed on loading the other cartridge. This is to check which cartridge is causing the problem. Try this steps maybe 2 or 3 times until the printer recognizes the cartridges. If problem persists, I strongly advise you to contact Lexmark at 1-800-LEXMARK(1-800-539-6275). You probably got defective cartridges.
Where can i download ocr so my x7675 will scan?
The Lexmark OCR scan software can only be installed using the installation cd that came with the Lexmark X7675 printer. It's not available for download. If you don't have the installation cd or you lost it, I advise you to call Lexmark at 1-800-LEXMARK (1-800-539-6275). They can better assist you with that request. Hope this helps. If you need more assistance, place a comment so I can get back to it. Thanks.
1helpful
I WANT DRIVERS FOR LEXMARK Z100
It would have been better if you posted the exact model number of your printer (e.g. Z2420, Z1300, X7675, etc.) and the operating system of your computer. But here's a link to the Lexmark website where you can download the drivers. Just click on the link: http://bit.ly/aiWCx4 . Type the exact model number (e.g. Lexmark Z2420, Z1300, X7675, etc.) on the bar just below the images of some of Lexmark's printers then hit Select. On the next page, choose the correct driver compatible for your computer's operating system. Download and install the driver. Hope this helps.
Install of X7675 Lexmark, chrashes on install of scanner
Please ensure you have the latest driver, you can get it from:
http://downloads.lexmark.com/perl/downloads/downloads.cgi?os_used=Windows%20XP&mode=OS&ccs=229:1:0:111:0:0
Also Let me know how is the printer connected to the computer, is it via USB cable or Wireless ?. Are you doing the install by executing the Setup.exe from the CD ? Or via PnP.
If you are seeing the problem with Setup.exe, I would recommend trying a PnP..for this you may want to uninstall any previous copies of the driver. Plug in the printer using the USB cable.
The first "Found new hardwate wizard" is for the scan driver, install it by pointing to the ".DriversScan" folder. If this is successful, the next prompt will be for a Print driver, point it to "DriversWin_XP2k" folder and let it finish the install.
Let me know how this goes.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
