Question about Ovens
We cannot turn the oven on! No instruction manual. The 'A' is flashing on the 'clock'/timer - what does this mean?
    Champion:
  • 235 Answers
This means it is in auto mode. It must be in manual mode for the oven to work. Turn the oven to ON. Some clocks have 2 or 3 buttons. Press the buttons at the same time/try all different combinations. This might take a few minutes, be patient. When the oven indicator lights the clock is in manual mode.
Posted on Apr 01, 2011
6ya staff
SOURCE:
I have a new Neff U15E52N3GB oven and I have to reprogram the clock each time I want to use it. Am I missing something on the original set up or is it a Naff Neff?
you are, that sounds like your setting the timer for cooking not the clock.....switch the hole thing off at the wall then put it back on, the clock should flash, then set it, check the manual for button config.
infact i just read it, & its on page 10 2nd paragraph on right hand side...........
You can only change the clock when no other clock function is
active.
ie switch it off & back on at the wall.
1.Press the < > clock function button repeatedly until
the< > O(pic of a clock) and symbols light up.
2. Set the clock using the rotary selector.
The setting is applied automatically
Dec 12, 2014 | Neff Ovens
Oven is not working its 5 years frigdare electronic elements are ok
Try setting clock before presuming board is faulty, ovens shouldn't work if clock is flashing or timer is counting down or bell symbol flashing. Consult your instructions
warmest regards
Richard The Repairman
Mar 29, 2014 | Frigidaire FEB30S5D Electric Single Oven
I have a frigidaire stove and the timer sets itself at any time of day or night...
You may find the necessary information related to your problem among these manuals Oven service manual download repair manuals installation schematic... Just choose your oven manufacturer and model.
Mar 24, 2014 | Ovens
Since a power cut yesterday, our Tecnik 8522 oven has flashing 'A' (Auto) on the clock & the bottom oven does not work. I know I have to reset the time to get te A off but no buttons work on the facia...
If you cannot change it from auto. to manual it doesn't mean you need a new oven. The electronic timer can be by-passed fairly easily by joining the active and oven load wire together..
Feb 10, 2011 | Ovens
I have a diplomat double oven no instruction or model no the bottom oven will not turn on and i can not get timer to cancel also an a is flashing on top left hand side of clock can you help ?
Sounds like the flashing 'a' means the timer is in automatic mode. I trust that when you turn the bottom oven to on the oven indicator light does not come on. Turn the bottom oven to ON. Then
have a fiddle with the timer. You have to get it to manuel mode. When it goes on to manuel mode the oven indicator light will come on and the oven will then work.
Feb 05, 2011 | Ovens
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
How do you set the clock on an electrolux premier built in single oven after a power cut as time is flashing and auto is showing and only four buttons and no instruction manual.
hold down the first two buttons on the far left then turn the little diel button,this will set the time.also you can set the timer useing one button hope this helps roscargou.
Feb 15, 2010 | Electrolux Ovens
Turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Jan 23, 2010 | Ovens
The oven won't come on, the digital timer just flashes continuous
Hi
have you tried setting the clock as the oven wont work if the clock is not set. hope this helps
regards dan
Mar 19, 2009 | De Dietrich UMP404 Powerclean Stainless...
Manual needed for Range operation: Specifically timer reset
I found the work-around to be to decrement the timer to 0 as a means of canceling it, "unset it" if you will.
Dec 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
295 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
