Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Posted on Apr 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On rinse cycle...cannot control water temperature...set it for warm but still feels cold to touch. wash cycle is ok. model is whirlpool gold ultimate care II..top loader.
honeymokey
Level 3:
President:
  • Master 3,113 Answers
  • Posted on Apr 01, 2011
honeymokey
Master
Level 3:
President:
Answers
3113
Questions
Helped
1023958
Points
7683
Is the hot water turned on. Remove hose from washer and check screen in water inlet. If it is clear you may need a new water inlet valve.
LG topload washer skips the rinse cycle. Washer fills, washes, drains, spins just fine. But instead of refilling for rinse cycle, it just spins for last 20 mins. Rinse & spin only cycle works fine.
Try changing temperature settings. It might be that one of your water valves is not working. As an example, if you are washing on warm, then the hot will work, but not the cold as it tries to mix the two, but you will still get water to correct level. But if it's trying to rinse on cold only and the cold valve isn't working, you get no water. So play around with settings and see if you can find the issue. A valve is pretty easy to replace and inexpensive. Check out videos on YouTube or repairclinic.com or appliancepartspros.com. Let us know how it all works out.
2answers
Rinse cycle water temp
You may have a leaking hot water electrovalve, replace it.
Why does it take so long to wash cloths I have done everything 1 hour and half still washing
Hi Robin,
Many washers have different wash settings and rinses in addition to temperature options and water levels (or load size). The temperatures wont affect the wash times (but hot and warm water washes will cost you more for the expense of making the hot water), so choose whichever you think you need. The water level makes a small impact each time it needs to be filled (wash, rinse, etc.). A warm wash will fill in half the time as either a cold or hot wash - as both hot and cold water are combined to make a "warm" water cycle.
A "Normal" or "Regular" wash without a pre-soak or pre-wash cycle and a single rinse is usually sufficient for *most* laundry needs - especially if you're using dryer sheets. Otherwise, you may find fabric softener is not rinsed out enough to your liking (or not - it's a personal choice).
If your machine offers a "Max Extract" or longer spin setting - it is worth running it to reduce the amount of time they're in the expensive-to-use dryer.
If you need more help - provide your washer brand and model.
What is the acuwash sensor
Washer temperature sensors and water level settings
The temperature of your washer's water varies with your laundry care needs. Standard washer models typically feature three temperature settings: Hot/Cold, Warm/Cold, and Cold/Cold—and higher-end models often offer as many as six or seven temperature settings. Temperature plays a key role in the effectiveness of your detergent—pairing the right detergent with the right setting for your fabrics and soil is important, as this will help reduce damage, prevent detergent residue, and provide the best wash across fabric types. For the best fabric care, look for washing machines with automatic temperature control (ATC). A sensor will control water temperature and ensure cold washes are above 60 degrees (F) to dissolve detergents, and warm washes do not exceed 93 degrees (F) to help prevent shrinking and bleeding.
The amount of water you use for each load also affects washer performance. Doing laundry is a bit like a science project. You need to make sure you are using the right volume of water, with the proper amount of detergent based on the dirt level of the laundry being cleaned. Too much of one component can result in a less-than-perfect outcome. Standard washing machines allow you to select water levels for different size loads, but some models offer more water-level options. Washers with automatic water levels use sensors to determine load size and adjust water level for best cleaning and rinsing performance. You will generally find these options in higher-priced top-loading washers. A benefit of front-loading washing machines is that most come with this automatic water-leveling feature.
Whirlpool® AccuWash™ temperature control sensor provides a temperature-controlled wash.
this is an article from the whirpool website, u can get a manual printed or downloaded by going to whirlpool.com and going to owners center and typing in ur model number.......
No cold water
souds like the cold valve has gone get and expert in to change it or change it yourself you can get parts from espares
No water enters on rinse cycle
I was partially wrong on my diagnosis. No cold water enters on either the wash or the rinse cycles. I also heard odd noises from the inlet valves. I realized the cold water valve was not opening. I've ordered the mixing valve and plan to replace it as soon as it comes in.
1helpful
Water temperature control not working
the fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
1helpful
2answers
Does Not Rinse
Check each temperature during initial wash fill. Set to hot water, is hot water coming out? Set to cold water, is cold water coming out? The rinse cycle is cold only. If cold water is not working machine will just stop at rinse.
If cold water not working:
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still not working, replace valve.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
