If you have no leaks the first thing I'd check is the ring and cylinder for wear. The cylinder wear is usually pretty obvious, but if you can see light around the piston ring it's bad. The replacement part number is N038785. Also check to make sure no valves on the valve plate part number A09819 are broken or bent.
Check
for leaks all over the machine. Possibly the O ring on the drain valve
is damaged. If the machine is oil-less, the big rubber O ring on the
piston could be worn away.
When the machine is turned off can you hear air leaking from anywhere?
I check all over, and there were no leaks. Drain valve works properly, but does have a little water coming out of it when i purge it. I check both rubber O rings in front and behind the valve plate, no damage. When the machine is off, i dont hear anything leaking.
Here is the parts schematic for the compressor:
http://shoppingcart.msservicecompany.com...
The piston ring may be damaged or worn or there may be a broken reed on the valve plate.
Here is a parts diagram for the air compressor:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/D55168/D55168_PL.pdf
There are a couple of things to look for on the air compressor.
You will need to see if the piston ring is damaged or if you have a broken reed on the valve plate.
These are typically the two most common problems with this model.
There were no leaks anywhere, i checked the Rubber O rings in front and behind the valve plate and there was no damage at all. When the machine is off nothing is leaking.
