SOURCE: cig lighter fuse blew. renewed but cig lighter and remote key not
you probably didnt change the right fuse and had another one blown at the same time you also could have a primary fuse under the hood that blew. once fixed dont use pump again. not same amps drawn
SOURCE: I have no audio from my stereo
If you're not an electrician or a certified Hyundai Technician, find one. Let them diagnose the problem you described.
SOURCE: 12v outlet fuses keep blowing.
Faulty reciever ,,, Worth checking the plug assy for internal damage . Check that the sat receiver is within the power capabilities of the vehicles acessory plugs < 10amp .
SOURCE: replacing the rear cig lighter with a after market
fuses number 1 and 4 in you under hood fuse panel control the rear outlets both are 25a fuses your front lighter is powered by number3 in the fuse panel under the drivers side of the dash.
